Thread: Getting FiFi Off My Dash
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Default Getting FiFi Off My Dash
    As I've now got TomTom 510, I don't need the little hexagonal stick on magnet (which Tom Tom call a Fifi!) that's stuck on the top of my dash. In fact, it's a bit of a liability, as some low life might think that I've got something worth stealing.
    Anyone have any idea how I can get it off -it's stuck on with a fairly strong sticky pad, and I'm worried I might damage the dash if I lever it, or something.
    TIA, Phil
    Regular Member Nige's Avatar
    May 2006
    Derbyshire
    abit of hair dryer heat might help, also lighter fluid will help soften the glue/sticky pad and will evaporate before damaging anything, doubt it would anyway.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    nail varnish remover
    I would go for the hair drier approach first, might be enough to move it ...
    Luton, Beds
    Thanks, chaps.
    I'll tackle the task after I get back from Barcelona.
    Phil
    cambridgeshire
    Sticky Stuff remover from Lakeland is what you want, smells vaguely of oranges not found that it attcks plastics just leave it to soak in a bit.
    www.lakeland.co.uk I think it is or they have high street shops. Wives usually have heard of these places. All sorts of uses like getting Gaffa tape off cables.
    Ian B.
    Quote Originally Posted by yorkshireborn View Post
    I wouldn't put acetone anywhere near the dash finish. It attacks rubber/plastic and I reckon would make a lovely mess of that rubbery finish.
    Luton, Beds
    I think I'll start with the heat gun, then I'll see if a less aggressive solvent might work. I used to use isopropyl alcohol to get lable remnants out of printers in my field service days, so I'll give that a try.
    Phil
    Yep, Isopropyl Alcohol (Isopropanol) is unlikely to attack the plastic as it's not a solvent. I'd do what you just said - heat gun to soften it and let you get the plate off, then Isopropyl Alcohol to remove the residue.
  1. Facelift Dash Trim on a Pre face dash?
    By jordib in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 22:15
  2. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  3. Dash on, dash off Daniel Son.
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2011, 18:38
  4. Red Dash
    By brian75 in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2009, 19:35
  5. new dash!!
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 17:41
