Results 1 to 10 of 15
Thread: Signum Clutch - Can you Adjust?
    Hants
    Default Signum Clutch - Can you Adjust?
    Hi all,
    Me again, I have a question about the clutch. It doesn't engage until the pedal is fairly high, is this normal?
    If not, can it be adjusted?
    morton
    which signum fella ?
    Hants
    Sorry!
    It's a 2.2dti Elite (53)
    nope, you cannot adjust.. it's all done with hydraulics these days..it's gearbox off time for a lookeysee i fear..
    Hants
    Default It slipped!
    Hi all,
    Went from 3rd to 4th whilst going up hill, admitidly i slipped it into gear whilst accelerating but once the foot was off the clutch it carried on slipping!
    As there is no adjustment i'm guessing it's a new clutch needed, what sort of cost am i looking at?
    Cheers!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would not go anywhere near a dealer for that job.
    In fact I wouldn't go anywhere. How handy are you? Is a clutch change possible for you?
    Is there any local garage that has a good reputation / or you're used before and would recommend? Save some cash by phoning around. It may be better if you supply the parts too.
    While the gearbox is off, it may be a good idea to change the clutch release cylinder at the same time. It may save you a few bob in the long term. You don't want to scrimp and then in a few weeks time have to pay for a new release to be fitted . . . . . .
    What mileage are you at with it?
    Nicking Ya Dinner.
    Not always mate, I used to get this from time to time especially when loaded up or giving it some, I think if anything the clutch over heats too easily tbh.
    Hants
    Quote Originally Posted by Ste View Post
    I could possibly do it, managed to change the crankshaft pulley but I'm guessing this is far more! Where would i find instructions?
    It's done 80k and yes there are a couple of local garages i could try.
    VauxVeteran: That's a good point........... I was 3hrs into a drive to cornwall and the car was loaded!
    My concern is that i'm driving from Calais to West Brittany this summer!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Even if it was hot, overloaded etc, a slipping clutch means one thing - - it will continue to slip and will eventually do it at all driving conditions. It's only a matter of time and where it finally gives up the ghost. If you'd been driving for a while, then the clutch wouldn't be hot, as it wouldn't be doing much if you weren't changing gears.
    Why wait to break down on the motorway when you're on your way to the most important meeting??
    Get some quotes for the job, BUT do ask what replacement parts are being used, and if necessary supply your own.
    If you want to do it yourself, then instructions can be found by asking the nice people on here if they can send you something. I'm sure someone will have access to the necessary info . . . (hint)
  1. signum clutch problems
    By dave_3 in forum Engine & Drivetrain
    Last Post: 15th January 2011, 19:41
  2. can u adjust stock boost solenoid on 2.0T signum
    By total_vxl in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2010, 20:07
  3. Flywheel/clutch signum
    By HONESTJOE in forum Engine & Drivetrain
    Last Post: 7th March 2010, 17:17
  4. Signum clutch?
    By peterh in forum Suspension, Wheels & Brakes
    Last Post: 20th October 2007, 18:04
  5. Signum Clutch
    By david173 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2006, 22:51
vauxhall vectra elite 06 clutch adjuster
can i adjust the clutch on vectra c
how to adjust a clutch signum 07
vectra c clutch slip when hot
vectra c clutch adjustment
vectra c clutch pedal adjustment
