Results 1 to 10 of 11
Thread: I don't want the radio on!!
    Regular Member Xorro's Avatar
    Northants
    Default I don't want the radio on!!
    Could someone tell me, if it is possible, how to stop the radio/CD coming on whenever I start the car?
    It gets a bit annoying having to keep turning it off.
    *edit* should mention that I have a CD70
    Yes, on the CD70 I think you do it in a menu through the display using the System button (I think) to get into the menu. I don't have a CD70 so don't know the exact sequence - on my CCR2006 it's done by holding and pressing the on button whilst turning the ignition on - or something like that. Have a look in your audio manual and it'll be in the index under something like Ignition On. You can turn it off so that the unit will only turn on with ignition if you turned off the ignition with the unit on.
    HTH
    Northants
    I had to read that bit 3 times, lol.
    Thanks Duncan, I'll dig out the book when I get home
    Quote Originally Posted by Xorro View Post
    Regular Member SignumPhil's Avatar
    Luton, Beds
    I get this trouble on my 2006, but it seems to be something to do with the Nokia car kit.
    I'll have a look in the book, though.
    Phil
    Regular Member Nige's Avatar
    May 2006
    Derbyshire
    Its an option in one of the setup menus, called something like power or ignition features?
    the same menu where you can alter the day and night colour
    it's called ignition logic in the CD30's.. so it would be the same on the CD70's surely?..
    Luton, Beds
    I wouldn't know, I've got a CCR2006.
    And don't call me Shirley........
    Phil
    right.. logged on to the VX website and it tells me you can turn off the ignition logic on a CCR2006 like this....
    switch on the ignition..
    turn the radio off with the power button
    press and hold in preset buttons 1 and 3 simultaniously..do not let go..
    turn on the radio power again..
    hold in 1 and 3 until you hear a conformation 'beep' and the display shows the message 'ignition logic on/off' and it changes to logic 'off'..
    to reverse it, just do the same thing again and it will flip states back to ignition controlled..
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    On CD70: in main menu... push 'settings'... ignition logic: disable
  1. CDC 40 radio
    By dave b in forum Electrical & ICE (including SatNav)
    Last Post: 23rd October 2012, 23:20
  2. Radio 1
    By vec-cal in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 00:17
  3. my radio
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2010, 21:29
  4. CD 30 Radio
    By Stevel in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 13th July 2008, 17:15
