Results 1 to 10 of 14
Thread: dti wont start
    Feb 2007
    spalding
    Default dti wont start
    Helppp I have a 1999 1998cc dti which was ok when I left it overnight but wouldnt start the next morning the local garage says its Injector problem and want £1500 to repair it sheesh
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Injector seals on these can be a problem I think? Other one is blocked fuel return pipes...
    Though injector seals at that price!
    What did garage says?
    Feb 2007
    spalding
    Injector pump U/S
    Central Scotland
    No luck mate. I know how you feel.
    I had the same problem on my astra 2.0 dti. If I left it on a slope with the rear end down the slope the fuel would drain back to the tank and the ****** wouldnt start. Left it the other way and it started fine. Went on like this for a while till it died on the motorway.
    New injector pump cost me £850. Could not complain too much I suppose because the car had done 140K plus when it died.
    Traded it in for my Vectra end of last year.
    Ian
    morton
    have you tried the leak off pipes ??? thats what was at fault on the wifes 2.2 dti ! only cost 3 quid for the amount you need too ! is the eng check light on ??
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does it not start at all???
    If it takes AGES cranking to get it going, and after AGES there is white diesel smoke and a STRONG smell of diesel, then I would say it is the leak off pipes. These are small bore rubber tubes going from injector to injector and then returns to the fuel system.
    If the engine was running fine then night before, and then failed to start in the morning, I would not leap into condemning the injection pump just yet. They normally don't suddenly go, unless the electronic control unit has failed suddenly.
    IMO, if the engine fires EVENTUALLY, then I would suspect the leak off pipes.
    morton
    its so cheap to replace them he'd be crazy not to try them first dont you think ??
    Feb 2007
    spalding
    Default dti not starting
    hi everyone no it wont start at all now, anyone no of price for cheap pump maybe if thats the last suggestion, hope not
    Feb 2007
    spalding
    whats the control unit please, as you gather I,m no mechanic
    the control unit is the main engine 'BRAIN'..and the pump will be an awful lot of money..in the order of one thousand pounds..
    I'd get the car fully checked out before you attempt any repairs..you could get lucky and have something simple fixed for 100 quid..or it could be far more involved..get it checked out properly as it will save you money in the long run..
  1. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
