Thread: Ignition power
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    Default Ignition power
    is there anywhere around the interior light i can take ignition power.
    im hopin i dont have to run cable down the pillars to the dash.
    what im plannin to do is mount my road angel near the rear view mirror somewhere and hardwire it in.
    thanks
    carl
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    i had to run a ign live from the f/box for a snooper,its not a bad job 10min max,just drop out the sunglasses holder and leave the light consul in place.
    did u just tuck the cables under the roof edge and the pillars? or did u take them out etc
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I pulled the door seal off and ran it in the space behind, this kept it away from the airbags and used a large cable tie to feed it across above the headlining just mind the cable doesn't chafe on the support in the roof.
  1. 12v ignition
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2012, 20:10
  2. Turned ignition key, no power...
    By izonoky in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2012, 13:05
  3. No ignition
    By pud wayman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 01:26
  4. ignition +ve
    By abz007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2007, 12:22
  5. Taking Power Outlets off Ignition?
    By chrisschild in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2006, 19:33
