Thread: can you wire in an amp into....
    Feb 2007
    work
    Default can you wire in an amp into....
    .....one of the vectra headunits.
    im looking at a car which has the uprated cd70 mp3 stereo and i have an amp and sub i want to install.
    just checking that there is an RCA output on the back of these headunits?
    can any1 confirm for me please?
    many thanks
    Regular Member The Doc's Avatar
    'Norf Yorks.
    No RCA output, but you can soon add one. I added one onto the Vectra and my Astra CD30's.
    Costs about £12 for the part and hours work worst...
    Nicking Ya Dinner.
    I think you can, have you checked out the ICE threads, I'm sure it's been topic'd before. hth.
    Ahh, you beat me to it John.
    Feb 2007
    work
    whoops - wrong forum, eh?!!i'll check the ice bit!!
    Hertfordshire
    No probs, moved to the Ice forum.
    As the guys say, it is unlikely you will ever find a factory fitted head unit with RCA's on it.
    Some amps can take high level inputs direct, or as said, the signal can be converted cheaply enough.
    Feb 2007
    work
    thank u.
    so if i buy a car with this headunit how easy will it be to wire in my amp and sub?
    it is an upgraded headunit so i belive with sat nav so dont really wanna mess about with an aftermarket headunit
    however i do like my sounds and want to make sure its poss to hook up the rest of my ICE......
    Hertfordshire
    The units I have seen need to be wired to the headunit speaker outputs.
    Personally I would see if I could find a lead to sit between the factory loom and the factory headunit. This way you could solder connections in place(which is a hell of a lot better than crimp terminals) without messing around with and cutting any factory wires.
    Feb 2007
    work
    ahh cool thanx - i'll suggest this to my mate who will install it for me as im pretty clueless with ICE installs!!
  1. What wire do I cut lol
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2012, 09:01
  2. Which Wire ?
    By Ste in forum The 'Off Topic' room
    Last Post: 9th September 2012, 22:24
  3. Is this an ABS Wire?
    By asgharuk in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 19:32
  4. 12 wire
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 22:02
  5. tel mute wire
    By jonesyboy in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2009, 22:33
