Results 1 to 10 of 16
Thread: Lowering The Vec
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    Default Lowering The Vec
    Hi Guys,
    Does anybody know if the vectra has rear independant suspension?
    All replies welcome
    Neil
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Yes she does Neil, although someone will correct me if im wrong
    morton
    yes it does ! and camber adjustment too !! which must be altered once its lowered !!
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    veccy22: how do u alter the camber?
    morton
    sent it via email ! did you get it ??
    never recieved anything mate.
    morton
    thats wierd !?? you only need a couple of spanners ! the adjusters are on cams , so you just twist them until the hub looks at its most upright !! the adjusters have marks on them ! but i dont know the technical settings !? i did mine by eye and she was spot on !! but altering the camber is a must !!!!!
    Jul 2006
    Presumably the garage i'm taking mine to will know about this?...
    i never knew u could alter the camber without a kit. i was about to buy a K-Mac rear camber kit for mine, as i have quite a bit of camber on the back.
    morton
    i found out the hard way !! scrubbed the rear tyres off in less than 3k !! imo if you go lower than 40mm ?? the adjusters wont take up the excess camber gained by lowering !!
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
