Results 1 to 3 of 3
Thread: suspension, springs and wheel bearings
    manchester
    Smile suspension, springs and wheel bearings
    hi all,
    does anyone know how much it will cost for new suspension and springs front only and also wheel bearings? or a steering rack would cost to replace on a vectra c 02 reg.
    thanx ozzye
    a long list....
    the following are guide prices for the bits, and labour times are an educated guess based on experience..
    the front dampers would be in the order of 100 quid the pair, and the springs would be the same price to buy.. fitting both in a professional enviroment would take about 1.5hrs to swap over the strut and spring onto your car.
    wheel bearings are avaliable on ebay for under the magic 100, but they will be about 140 from VX.. fitting isn't a big job but allow about an hour a side to do.. and use plenty of penetrating oil..
    the biggy is the rack..as of yet i haven't come across anyone who sells recon racks, so new is the only option..and they're the thick end of 400 quid..fitting is a swine as you have to droop the back of the engine subframe to get them in and out.. this means disturbing some rather expensive stretch bolts to release the tail of the subframe..labour is about 3 hours to do..so don't expect much change out of 800 quid on it..
    manchester
    thanx for the reply mate
    thank you for the estimate
  1. Wheel Bearings
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2009, 13:52
  2. Wheel bearings
    By John3v36 in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2008, 22:10
  3. Wheel bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2008, 10:08
  4. wheel bearings
    By blackbeauty in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2007, 21:21
  5. Wheel bearings
    By Allan-Sri in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2006, 21:09
