Results 1 to 3 of 3
Thread: Bust electric mirror
    May 2006
    Leeds
    Default Bust electric mirror
    Found my electric mirror has been popped off the mechanism last night.
    Looks like one of the local chavs decided he couldn't keep his hands to
    himself, and wanted to check his poxy inbred face in my drivers side mirror .
    The glass was tilted as far up as it will go, and is now manual aim only.
    The motor is still whirring inside when the buttons are pressed, but only
    moves in one direction occasionally if it catches it right. The working one
    is fairly firm, wheras the broken one is looser and can be positioned, and
    does not flop to a resting position.
    Will I be able to pop it back onto the whirring mechanism if I open it up,
    will glue/epoxy putty re-enforcement be required, or a new unit. It is an
    03 Signum 2.0 DTI Elegance.
    Bob
    you should be able to prise off the glass as it just snaps onto the motor face...somewhere round here is a how-2.. i'll be back in a mo with a linky..
    http://www.vectra-c.com/forum/showthread.php?t=16252
    that'll show you the motor housing.. it's the circular ring in the middle of the mirror...
    if you use two spatula's you should be able to put them behind the glass and pop it off the retainer ring.. that'll let you get in to the motor..
    May 2006
    Leeds
    Well, there are 2 electric motors that drive 2 bendy rack and pinion type things, that are the same plastic as cable ties (the two white bits near the screws inside the circle in the first photo in your link). These have been snapped, and are too small to glue or repair in any way. It looks like I will have to buy a new unit, when all I need is the mechanism.
    Bob
  1. electric mirror
    By silky in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 15:22
  2. Electric interior mirror
    By portreathbeach in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2012, 19:04
  3. electric mirror fault
    By TAL in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2010, 14:33
  4. electric mirror fault
    By beakster in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2009, 19:54
  5. Electric door mirror....
    By swirl80 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 15:26
