Thread: Removing rear bumper
    Regular Member danlat1415's Avatar
    Lancashire
    Default Removing rear bumper
    Does anyone know how to remove rear bumper from the Vectra?
    I'm upgrading from LS/SXi bumper to SRI and I'll do it today if it doesn't rain too much.
    Maybe attempt the SRI Backbox upgrade too.
    Dan
    yep, it's easy..
    remove the torx screws from the rear of the rear wheel arch liners, both sides..
    remove the 2 torx screws from up by the rear number plate lamps..
    remove both the rear light clusters ( hidden bumper lugs behind them)..
    now, starting from the wheelarch, gently pull the bumper out of the friction fitting on the 1/4 panels, till you get back to the hole where the lights where...it will be tight, but you can get your hand behind to push them out of the clip..
    then prise the lugs out of the fittings in the light cluster hole.
    repeat for the other side..
    now just pull it back, off the boot lip friction fitting, and it will fall off
    remove the number plate lamp wiring connector..check the 2 lower tabs have fell off as well..
    bumper is now off..
    Lancashire
    I'll give it a go later when I've woken up a bit.
    And pics will follow.
    Its the law!!!....
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by danlat1415 View Post
    Excellent - we haven't got a How 2 with pics for rear bumper removal yet!
    Lancashire
    Got called off on account of the rain.
    I seem to have a problem with it too. When I put the new bumper next to the car, the colour seems to be different. The bumper seems to have a slight brownish tint to it, and not a crisp black that it should be. Sorry no pics.
    It got worse orange peel effect than the original paintwork so it's going back to the paintshop with some harsh words!! I didn't notice when I picked it up because it was half 4 and getting dark.
    Hmmm.. thats not good is it....
    still, at least you didn't see it when it was fitted to the car....
  1. Removing estate rear bumper
    By Marky in forum Bodywork & Interior
    Last Post: 1st August 2012, 14:28
  2. removing rear ESTATE bumper
    By iasha in forum Bodywork & Interior
    Last Post: 16th March 2010, 16:02
  3. Removing SRi Rear bumper insert
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2010, 21:25
  4. Removing rear skirt from bumper
    By Baz07 in forum Bodywork & Interior
    Last Post: 25th April 2008, 23:00
  5. help removing rear bumper
    By simon7257 in forum Styling
    Last Post: 14th September 2007, 20:42
removing vectra c rear bumper
vectra c remove lower lip on rear bumper
https:www.vectra-c.comforumshowthread.php18935-Removing-rear-bumper
how to remove vectra c rear bumper
haynes vauxhall vectra c removing rear bumper
vauxhall vectra rear bumper removal
removing vauxhall rear bumper on vectra
vecta c rear bumper clip to wheel arch
vauxhall vectra c rear bumper remova
