Thread: Brakes? in snow
    Regular Member Majorlook's Avatar
    Leicester
    Default Brakes? in snow
    Hi I got a 2.2 vectra c auto (03) and today because it was snowing pressed the little button with a pic of a snow flake on it. Pulled off and the first time i broke there was a wierd juddering in the brake peddle and it felt like there was metal against metal in the brakes. Turned off snowflake button (sorry not sure of real name for it) and its fine any ideas?
    Regular Member simac's Avatar
    Wirral
    The juddering sounds like the ABS activating, someone should be along with a more technical explanation soon !
    Regular Member denzo's Avatar
    Runcorn
    Yeah .... by pressing the button you are disabling the traction control hence the juddering and difficulty driving.
    Having the button off means that Traction Control is activated .. hence greater stability
    Jan 2006
    Skynet HQ EMEC#5
    I thought that the snowflake button on auto boxes started you off in a lower gear to prevent wheelspin?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    As yours is a auto the snowflake button is for winter mode,this used to mean the car pulled away in 2nd,but with modern electronics it could change even more settings. The juddering does sound like abs cutting in due to poor grip.
    Runcorn
    Sorry .... Snowflake .... I misread the posting regarding auto box ... Yep, it starts off in a higher gear (2nd)
    Just off to Cyprus for a week's holiday definately no snow there !
    Jun 2006
    teeside
    i thought the little button with the snow flake was for the air con
  1. Replies: 2
    Last Post: 8th October 2011, 02:07
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Snow foamer and snow foam....
    By david.aka.judas in forum General items for sale
    Last Post: 11th April 2010, 22:27
  4. Snow sledges and snow shovels...
    By n_hudson in forum The 'Off Topic' room
    Last Post: 7th February 2009, 10:30
  5. how much snow have you got
    By learoy69 in forum General Chat
    Last Post: 23rd March 2008, 21:21
