Thread: face lift front end transplant
    morton
    confused face lift front end transplant
    thought i'd run this past you guys ! in the future i may update my phase1 'c' with the front end off the phase2 !! wonder if it will all bolt straight on . i think it may need a different slam panel etc ??? feel free to air your views !
    spoons
    Guest
    Wow...
    That will mean...
    - Bonnet & Fixings
    - Front Grill
    - Front Wings
    - Front Bumper
    - Front Headlights
    - All the fixings
    at least... major job !! - and thats if all that lot will fit onto the existing fixings...
    Regular Member Modifications's Avatar
    Sheffield
    i would say, get a face lift car. would work out cheaper
    SOMERSET
    Quote Originally Posted by spoons View Post
    Wow...
    That will mean...
    - Bonnet & Fixings
    - Front Grill
    - Front Wings
    - Front Bumper
    - Front Headlights
    - All the fixings
    But if you were not in a hurry you could pick this lot up secondhand, you would have to really love your pre c though
    Admin plasma's Avatar
    On the Forum
    216 Post(s)
    Engine : 150
    Mileage : 74000
    I can understand where hes coming from. I wanted to do put a Mk4 escort front onto a Mk3 when i was younger.. So good luck to him
    I reckon you're looking at -
    Bonnet
    Both front wings
    Headlights
    Slam panel
    Bulkhead
    Grille
    probably radiator mounts (for all rads)
    It would also depend on whether you have full canbus or half canbus
    I'm sure there's a lot more involved. I don't think it's worth the money matey; as said above go buy a facelift.
    There is someone doing it at the moment on the sit, and Matt knows someone who has done a GSi. so doable, but as above a lot of work / cash and probably make the car a nightmare to sell on / insure ...
    Would like to see some photos of the facelift GSi , a true one off ...
    Leicester
    I know a guy who has done a GSi, and to repeat his words "I'll never do it again'
    The list you need is :-
    1 x Bonnet
    2 x headlights
    2 x front wings
    1 x slam panel
    1 x lower cross member
    2 x front chassis legs
    1 x front bumper complete
    1 x radiator
    1 x A/C condenser rad
    I have spoken to the guy I know who has done this, The can bus system should'nt cause much concern if you are running standard headlights. All the bulb types on facelift and prefacelift are pretty much the same.
    So you can use the exixting loom, side lights, indicators have almost identical plugs, but you may need to extend the standard loom to make them reach, but this won't cause any hassle to the can bus as long as you use the correct low voltage wire where required, and standard wire where needed elsewhere.
    If your running zenons on your pre-facelift, you will need the standard facelift zenons from a VXR as this is the only car to run non AFL zenons in stadard form.
    Once you get these lights, again side light, main beam and indicators are a simple swap over, but you can use the zenon system already in place on your pre-facelift and simply modify the zenon bulb holder to fit the new light.
    It is a little more involved than that but the principle is easy. The VXR headlights were the most expensive part of Steve's conversion as he had to buy them new.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Any chance of him posting some pics Matt? Interesting project!
    Full Member VectraMat's Avatar
    Hull
    hmm, would certainly keep you busy
    as above it would be quite expensive to do, dont for get the labour for the spraying and fitting of some bits. but you could get some of your money back by selling the pre-facelift parts on.
    VXR Gone - Now in BMW 320cd M Sport Convertible
  1. Pre-face Lift & Face Lift Auto dimmin Rear View Mirrors
    By Meady in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 16:25
  2. Pre face lift front splitter which to go for
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2011, 21:39
  3. Front end face lift on pre facelift
    By Keithy in forum Bodywork & Interior
    Last Post: 23rd October 2009, 19:56
  4. New face lift front bumper
    By Kcs in forum Bodywork & Interior
    Last Post: 14th April 2007, 11:44
