My car is going back to Vx.
Everytime I turn the rear demister on, it makes my radio go crazy........
ne1 else had that?
ne1 else had that?
Had a similar problem on my previous Vec B when listening to AM frequencies, however it was fine when listening to FM.
Even stranger, the cure was to turn on the rear wiper for a couple of times and this sorted it out!
Vx could never find the cause.
Happened when I bought the Signum and also AM was non existant.
They changed the aerial booster and all ok.
Something in the back of my brain from my engineering degree is saying ground.....
Maybe someone who actually knows their stuff wil be along in a bit?
i had this problem on my vectra b, was told it was because my car had no external aerial and it used the element from the demister as an aerial, i got a new signal booster and it sorted it out
either change the ariel amplifier but also check the rear screen and ariel eathing point .
Perry, did the other frequencys work ok. I've got the CDC40 with DAB and AM has never worked but FM and DAB are AOK and because I have my external sat nav and nokia car kit wired and spliced in, the dealer wont look at it. I've got to have it all disconnected from the VX system first. Would unit did you have in your Siggy?
