Thread: Starting in the morning
    Regular Member thestaffy's Avatar
    belfast
    Default Starting in the morning
    Hi guys when i start my vectra in the mornings it starts right away but afrer about 5seconds it will die out and will take ages to start up again.Any ideas what could be wrong.It is a 2003 2.0dti i only serviced it on saturday
    it could be the old favorite , the injector leak back pipes.. do you have to crank it forever to get it to start again??.. if so they may well need replacing..
    did this happen only after the service?? is all the air bled out of the fuel filter?
    belfast
    I dont know how do i bleed the fuelfilter i thought if it was runing then the air would drain out itself.
    belfast
    Would they be under my warranty it covers the engine and gear box?
    it should be self bleeding, but is this a 'once only' occurance or has it been had to start for a while now?..
    Quote Originally Posted by thestaffy View Post
    blinking well should be...they attach to the fuel injectors on the engine, so they can't really refuse to change them..
    belfast
    How do i bleed the fuel filter to kmake sure it isnt that?
    i've just stopped myself typing the reply i'd give to a diesel fitter.. just because i've realised what i'm typing and how dangerous it is to do on the low pressure system, let alone a common rail one , in case someone came along and read this in the future..playing with diesel under pressure on a DTi is dangerous, playing with the CDTi fuel rail is suicidal..
    the safest bet, is get the car looked at with a veiw to the leak off pipes, then, if it does need bleeding or the like, they'll do it there and then in a much safer professional environment..that way no harm can come to you or anyone else who reads this in the future..
    Regular Member JCB's Avatar
    Oh, I forgot to remember!
    staffy - similar problem here!
    http://www.vectra-c.com/forum/showthread.php?t=18787
    Warranty?! Wont be covered on a 2003 car will it?!
    belfast
    I bought my car of a dealer with warranty
  1. Not starting..... Possible Starting Motor
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2012, 11:30
  2. Morning
    By MACVVT in forum Introduce yourself.
    Last Post: 2nd June 2011, 21:42
  3. EML flashing when starting but not starting (Vec-B)!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 29th July 2009, 15:51
  4. Morning
    By renry in forum Introduce yourself.
    Last Post: 22nd February 2009, 18:49
  5. Morning all
    By Big_Steve in forum Introduce yourself.
    Last Post: 28th June 2007, 20:49
