Results 1 to 10 of 14
Thread: Help Towbar Electrics
    Regular Member dan's Avatar
    Feb 2006
    Sunny Morecambe
    Default Help Towbar Electrics
    Hi folks.
    I have just had a Witter towbar fitted at dealers to my 05 cdti sri 150. I have tested lights on trailer and all are functioning correctly. Now am I right in thinking there should be a trailer light on dash, which should flash along with indicator < & > arrows, to let you know the trailer lights are working correctly? If so I do not have one. Should I take car back and have a moan?
    Thanks, Dan.
    Dec 2005
    St Helens
    Nope - ours just has a buzzer in the boot that was fitted with the tow electrics. It's annoying but the radio drowns it out
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    Default tow bar
    there's only a warning buzzer ,no warning lights
    Feb 2006
    Sunny Morecambe
    I don't even have a buzzer, it's just as if I have no trailer attached. I suppose if the trailer lights work then why complain, but if something is supposed to be there then why isn't it? Do you think maybe the dealer have not tech 2'd?
    darvel,ayrshire
    Default towbar
    you should have a warning buzzer on when you indicate,if i'm right in thinking it's actually a legal recquirment so i'd get it checked
    Feb 2006
    Sunny Morecambe
    Also just checked fuses in boot and F13 I believe should be a 20amp fuse not 10 which they've fitted.
    No buzzer on ours, and it was a genuine VX kit, tech2 and the whole kitchen sink..
    Portadown, N.I.
    Same here, had a whitter towbar fitted and a genuine GM vauxhall wiring kit fitted, but no bells / whistles / buzzers / extra lights on my 03 2.0Dti Ls.
    Tim
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Me to got a genuine VX towbar, tech 2'd no buzzer. just the occasional dash light out warning as the reversing buld has failed
    Feb 2007
    Leicestershire
    I also have a towbar on my Signum. Witter electric kit fitted inton the rear fuse box. No buzzers or dash warning lights.
    I had the same problem with a Vectr B. Took it up with the main stealer whos responce was to try taking an indicator bulb out of the trailer. The car indicators the go irratic just like when a bulb fails on the car itself. This according to VX is perfectly correct.
    So try taking a bulb out of your trailer and see what happens.
    Pete
  1. Towbar Electrics
    By slipperysam1984 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2010, 15:53
  2. Towbar Electrics
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2009, 19:05
  3. Vx Towbar Electrics
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2006, 08:42
  4. Towbar electrics
    By CPHB in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2005, 21:28
tow bar electrics for vauxhall vector 2007
