Thread: Cold Weather = Rough Starting
    Regular Member DesignforLife's Avatar
    Lancashire
    Question Cold Weather = Rough Starting
    Hi all,
    hope someone can help out here... I have a Signum 1.9CDti 150 Auto with 9K on the clock. Bought 2 weeks ago - all has been well. Only modification has been fitment of my 5 month old DTUK 'Green' box (set at 1oclock).
    I have noticed with the very low temps over the last few days:
    * When Cold starting the engine cranks longer & starts rough (chuggy)
    * The engine sounds nosier (I know its a diesel!!) & sluggish.
    Help!! It clears so so when warm & MPG seems ok etc - Is it the DTUK box causing this or is it something normal/ abnormal??
    P.S - My Astra had same engine with the same Box - with none of the above.....
    Cheers - Matt
    Regular Member Harry's Avatar
    Uxbridge, London
    try taking the box off for a few days and see what happens.
    Lancashire
    Thumbs up Its Fruggin Freezin!!
    Thanks for pointing that out Harry
    Its fuggin freezin out there at the mo!! Was hoping to get the box off tonight but those plastic clips are a mare in this weather!!
    Matt
    Uxbridge, London
    sorry mate i know its the obvious thing to do...but can't think of anything else to suggest
    Regular Member ion's Avatar
    walsall
    Yes, it's deffo the box.
    My CR1 does exactly the same.
    As the temp really drops more fuel is pushed in to aid starting.
    With a box on this is too much & makes it chug for a few seconds.
    My CR1 is off until conditions improve.
    Lancashire
    Thumbs up
    Thanks ION,
    will remove when it warms up mid - morning!! Cheers - Matt
    Feb 2007
    Telford
    Could be partially waxing diesel. If the car's been sitting on a forecourt for several months you might still have some summer diesel in the tank which will wax-up in cold weather.
    EVERYWHERE
    Quote Originally Posted by DesignforLife View Post
    Thanks ION,
    If it's adjustable,try turning it down a couple of clicks.
    Lancashire
    Thumbs up
    Thanks for the ideas chaps.
    * Waxing in fuel: - The car was on the forcourt for 4 weeks, Dec/Jan. + The first time I filled the tank - in went a bottle of injector cleaner.
    * Box is set at 1oclock - this is how they come from DTUK (should be around +15bhp & 10% torque at this setting.
    Update: - Box is off & guess what - none of the original symptoms - though it hasnt been as cold up here this week.
    Cheers, Matt
  1. signum 2.8 Rough Running When Cold
    By viper8 in forum Engine & Drivetrain
    Last Post: 7th August 2012, 23:15
  2. Rough Idle - Cold
    By mattcarpenter10 in forum Engine & Drivetrain
    Last Post: 23rd June 2011, 22:10
  3. cdti sounding rough when cold
    By leeky1 in forum Engine & Drivetrain
    Last Post: 16th March 2011, 15:43
  4. Rough starting from cold
    By TonyR999 in forum Engine & Drivetrain
    Last Post: 25th December 2006, 14:45
  5. 3.2 V6 Gsi Rough Running From Cold
    By TOON VECTRA V6 in forum Engine & Drivetrain
    Last Post: 13th December 2006, 22:20
