Thread: Radiator
    SOUTH SHIELDS
    Thumbs down Radiator
    Car started to leak water last friday hoyed some radweld in and all was fine over the weekend til monday night, in at garage today and told I need a new radiator, £181+VAT- trade discount just for the part then fitting on top apparently just about the whole front end needs to come off
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Unhappy Bad Luck!
    Mind you £181 isnt too bad ?? Not good but I've just got rid of a french thing (peugeot), when the rad went pop on that...£266 + VAT....OUCH!
    So far VX stealers dont seem too extortionate....
    Stand by hundreds of responses telling me otherwise!!
    it does sound dramatic, but all they mean is the removal of the bumper skin and the reinforcing bar.. just go get some good access..
    if you're keen then you could even do it on your own driveway at home, as there are no specialist tools required..
    cambs
    I did a rad change back end of last year, its no real drama!
    Got the new (pattern) rad from a small place in cambridge, was around £100 if i recall correctly.
    took about 4 hours including a drive to get new rad!
    you will need some new hose clamps as the VX ones are them daft things you SHOULD use fancy tools on
    As previously stated, drop front bumper off
    place front of car on axle stands
    detach air con rad from main rad and secure out of way
    undo fan power connector
    remove radiator hoses (X3)
    remove bottom rad mounts
    drop old leaky rad out <silly idea to have it come out from the bottom.>
    swap fan onto new rad.
    reassembly is the reverse of removal.....
    bleed system....
    SOUTH SHIELDS
    Well paid &#163;161 for the radiator from the stealers took it down to garage so should get car back today
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Air con radiator
    By sebadee in forum Vectra C / Signum Troubleshooting
    Last Post: 27th September 2011, 20:33
  3. radiator how to?
    By steve1412 in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:21
  4. Air con radiator
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 24th March 2010, 13:38
  5. Radiator
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 11th February 2009, 22:04
