Thread: Info required re: chipping/tuning 2.2dti
    Regular Member rozzer1976's Avatar
    Feb 2007
    Lanarkshire
    Vehicle : Vauxhall Astra
    Trim : SE
    Engine : 1.7 ecoflex cdti
    Year : 62
    confused Info required re: chipping/tuning 2.2dti
    Hi all, does anyone know what the score is with having a 53 plate 2.2dti chipped/tuned? I know that Tune-it offer a module however superchips say that they dont as that particular engine management system, is complicated. I checked the Celtic website and they dont do one for any cars newer than a 52 plate because of a hybrid ECU??? Help!
    you could get a VP44 tuning box for it, that hard wires into the fuel pumps loom.. that'll give you a marginal increase, stick in some airbox and filter mods, then a free 'er flowing exhaust and you should notice a difference..
    Here, there and every where!
    A VP44 will take you from 125bhp to approx 152bhp. As Mark says, with a pefrormance exhaust, panel filter and the airbox mod you will be up to around 160bhp
    More info HERE
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    i got the vp44, had a diagnostix check and it was 157bhp with 320 ft lb of tourque, and thats a 53 plate 2.2 dti, now got a k&n with free flow exhaust.
    Feb 2007
    Lanarkshire
    Trim : SE
    Year : 62
    Thanks for the advice Silver...having had it done, would you recommend it?
    Feb 2006
    Guttedsville
    Did I tell anyone mine has 144 bhp as standard?....
    Wonder what the new DTUK tuning box would do to it?
    Hmmm.
    Feb 2006
    walsall
    hi m8,
    i was thinking of getting mine done...i phoned `angel tuning` in warwick.they said that a 2.2 dti could not be done....& it wasn`t down to the hybrid ecu!..i also phoned `chipped uk`in worcestershire.they said it could be done,only if ,& this is where i got confused! he said something about the water pump...if your pump has a loom going to it,then it cant be done..if it hasn`t,then it can be done.
    hope this helps?
    thanks
    nev
    Feb 2007
    Lanarkshire
    Trim : SE
    Year : 62
    Cheers for the update Nev.
    Regular Member dervdoc's Avatar
    Co.Armagh
    with a motor that has a hybrid ecu a tuning box can be fitted ok, the tuning box should have 4 wires, one to the battery possitive, one to earth, one goes to a wire on the pump, which by the way is really really hard to get at , and the other wire goes to a throttle pedal sensor wire thats it, i fitted one to my 2.0dti about a month ago, she's a hybrid ecu and it works ok
  1. 2.2dti fault help required
    By sberrow in forum Engine & Drivetrain
    Last Post: 19th November 2010, 09:35
  2. INFO - required please vec 2.0T
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 10:11
  3. GSI info required please
    By falco in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 06:06
  4. A little info required
    By phil67 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2008, 11:27
  5. T I S info required
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2007, 22:07
