Thread: 4 wheel laser alignment
    Bonnie Scotland
    Default 4 wheel laser alignment
    The Tractor is pulling slightly to the left on a straight road. It's been lowered by 40mm so what settings do you guys go for when you go for an alignment?? Do you go for the settings as though the car isn't lowered or something completely different? Also how much should I be paying for a 4 wheel laser alignment? I read in a Jap perfomance mag about a car they were running and it was about £100. Does the engine need to be running when the alignment is being set?? If I've missed any other crucial questions could you please let me know.
    The engine MUST be running if it as power steering (which the Vectra C does)
    The difference between the front wheels should be zero
    Personally I always observe the tracking as they carry it out, and decide whether it is worth adjusting
    I use National Tyres Kirkintilloch, at £22 (£11 discounted) for check and adjust, FOC for a check only
    Always try to find equipment that is under 3 years old
    A full chassis calibration and alignment would probably cost about £80, main dealers only as far as I am aware
    spoons
    Guest
    I used MIJ Performance in Walsall.
    Cost me £40...
    Bonnie Scotland
    Will the settings need to be different as it is lowered?
    Spoons - would you mind if I used your VXRD logo on a number plate that I hope to get made up??
    spoons
    Guest
    Quote Originally Posted by James7 View Post
    Yes, the settings will be different if you've lowered the car...
    and.. No Problem with the VXRD badge... PM sent...
  1. Wheel Alighment (4 wheel laser)
    By Dane-10 in forum General Motoring Chat
    Last Post: 3rd April 2012, 15:18
  2. 4 Wheel 'Hunter' Laser Alignment done today
    By Taffyopel in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 19:32
  3. 4 wheel laser alignment- Central Scotland
    By James7 in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2007, 15:29
  4. 4 Wheel laser alignment
    By dougiemc in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2007, 21:29
