Thread: Adjusting the handbrake cable?
    Regular Member jamesr's Avatar
    Lancashire
    Default Adjusting the handbrake cable?
    Can I adjust the handbrake cable on an 04 Vectra C?
    If so can someone post a quick how to?
    Reason I ask, is, I live on a main road - parked the car in a side street after filling up with gas, about 30 mins later a guy knocked on the door -
    my car had rolled into the MIDDLE OF THE ROAD!!!
    HELP?!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    its got a self adjuster mate .........take it vack to a dealer to get the breaks checked...........
    Regular Member Harry's Avatar
    Uxbridge, London
    and leave it in gear when parked until you do get to the dealer!
    take it back in mate, VX will check the rear calipers operation.. if you're lucky winding the pistons back in and then letting the adjusters work again may be enough to reset it.. if you're unlucky it'll be one or more new calipers..
    Lancashire
    so can you not tighten the cable like on vectra b?
    nope... it's self adjusting at the caliper...if the cable has stretched then it'll need changing..
    The rear hub setup is nothing like a vec B.. the rear caliper is now quite a complex bit of kit compared to the B's..
    Regular Member breezephil's Avatar
    LONDON
    Now it couldnt be simple could it, I was wondering that myself now the other day, car started to slip a bit, but mind you it was a pretty savage hill - if I was parking on it it would be in gear for sure.
  1. handbrake cable
    By mbtech01 in forum Suspension, Wheels & Brakes
    Last Post: 15th August 2013, 16:47
  2. Who's replaced their handbrake cable?
    Last Post: 25th May 2011, 13:56
  3. Releasing handbrake self-adjusting mechanism
    By dnywra in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 11:53
  4. Handbrake cable
    By peadar in forum Vectra C / Signum Troubleshooting
    Last Post: 10th June 2008, 07:57
  5. handbrake cable
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 12:49
vauxhall vectra handbrake cable adjustment
vauxhall zafira 10 handbrake ajust
https:www.vectra-c.comforumshowthread.php18727-Adjusting-the-handbrake-cable
opel vectra c handbrake adjustment
vectra c handbrake cable adjustment
vectra b how to adjust handbrake cable
handbrake cable vectra c
adjusting handbrake on vauxhall vectra
2006 vauxhall vectra handbrake adjustment
adjust handbrake cable vectra
vectra c handbrake reset
vectra c handbrake reset www.vectra-c.com
2008 vauxhall vectra handbrake adjustment
adjusting handbrake. cectra c
how to tighten hanbrake cable vectra c
adjust vectra c handbrake
vx owners club resetting handbrake
vectra c handbrake adjuster www.vectra-c.com
2005 vauxhall vectra handbrake adjustment
how to fix vectra c handbrake
2008 vectra c where is hadbrake cable adjuster
