Thread: slight cracking noise from rear when pulling off, any common issues?
    newport
    Default slight cracking noise from rear when pulling off, any common issues?
    only does it when pulling initially pulling off, cant say i have noticed it when going over bumps or potholes, any common issues which would cause this? last week passed the mot with flying colours
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is it coming from suspension area, or maybe some plastic inside creaking?
    Sep 2010
    brake pad sticking?
    newport
    cheers both, got under the car and had a proper look around, was a simple thing in the end. the previous owner had had a rear shock replaced, and noticed that the bolt that holds it in was slightly loose and allowing a tiny bit of movement at the lower end of the shock, nipped it up, and noise gone
  1. vec c 1.8 vvt, what to look out for? any common issues?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2012, 00:03
  2. Rear creaking/cracking noise
    By andythilo in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 23:46
  3. cracking noise?
    By tonyblade in forum Bodywork & Interior
    Last Post: 11th June 2009, 00:06
  4. Replies: 0
    Last Post: 25th June 2005, 16:11
  5. FR 1516: C-Pillar - Cracking Noise (Vec C)
    By Duncan in forum Body & Body Equipment
    Last Post: 25th June 2005, 15:35
