Results 1 to 10 of 14
Thread: fault code
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default fault code
    Spanner light is on and tried the pedal test it flashed out 10-5-9-7 its a z18xer can someone help with what code this is thanks
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    googled it heres what it came up with, Thermostat Heater Control Circuit/Open
    What does this mean?
    OBD Code P0597refers to
    Causes
    Possible causes of OBD code P0597
    - Open or short thermostat heather control circuit - Poor thermostat heather control circuit connection - Failed Engine Cooling Thermostat The Error code is generally activated on detection of the following conditions: The P0597 is triggered when there is an open or short thermostat heather control circuit.
    Possible Solutions
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    New thermostat needed, best to get housing, will come with thermostat fitted.
    Dec 2011
    Seaham
    The thermostat and housing are a single unit. The ZX18ER has an electronic thermostat, where there is an electric solenoid to open and close the gate. It sounds like the solenoid has stopped working or has a fault.
    I got my new one from GSF
    http://www.gsfcarparts.com/parts/coo...tem/thermostat
    But it looks like they are out of stock? It only took about 30 minutes to change. make sure you buy some anti-freeze concentrate to top up your system.
    Do not over tighten the bolts as they go into a plastic casting. I did a How 2, it will be on here somewhere??
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    I have just put a new thermostat on the car and housing only 3 weeks ago was fine until yesterday
    Dec 2011
    Seaham
    Make sure that it is corectly plugged in, otherwise it could well be a faulty unit?
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    made sure it was on properly, kept my old unit putting this on as we speak
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Put the old thermostat on and no spanner light must be a faulty unit,could i return this to ECP and get my money back ?
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    thay should do as its faulty bud
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Lost the receipt so i dont think they will take it back
  1. fault code help code p1565
    By Hodgy in forum Engine & Drivetrain
    Last Post: 3rd January 2021, 15:11
  2. p1792-71 gearbox fault code plus alarm sensor fault codes
    By stu f in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2013, 21:05
  3. Fault Code App
    By Keefyb007 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 21:35
  4. fault code
    By mats13 in forum Engine & Drivetrain
    Last Post: 22nd March 2010, 23:28
  5. Fault code ID
    By Jamesdti in forum Engine & Drivetrain
    Last Post: 21st March 2008, 04:24
vectra c p0597-04 code
vectra c 07 error 0597
