Thread: Auto lights always on
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Default Auto lights always on
    Hi,
    For some reason my headlights are always on. The switch is set to Auto, but the headlights come on even in bright daylight.
    Any ideas? Is there a sensor I could clean or something?
    Many thanks.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Try cleaning the plug to the light switch mate. If you take the switch out then the lights come on with the key. A dirty connector may be causing the same.
    Wirral / ellesmere port
    13 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    its either the faulty rain sensor as the rain sensor has the auto
    light sensor built into 1 unit.
    or the roof ribbon behind the roof alarm ultrasonic sensor panel
    cud be ripped but this only happens if the screen has been
    replaced as windscreen fitters always forget its attached and
    they seem to damage the ribbon.
    had about 3 of these within the last few months
    Bradford
    Trim : Elite Auto
    Hmmm... I had disconnected the Rain Sensor ribbon a while ago (and reverted to standard intermittent wipers). Maybe that's what has caused the auto-lights to be permanently on? I'll re-connect it tomorrow and see how that goes.
    Many thanks for the replies...
    13 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by ShamusUK View Post
    yeah that be the problem if its not connected then it be an open circuit which will
    make your headlamps stay on because its not letting the light sensor do its job
    Bradford
    Trim : Elite Auto
    Quote Originally Posted by andy.l View Post
    Does that mean there is no way of disabling the rain sensor without messing up the auto-lights?
    Bradford
    Trim : Elite Auto
    Well I reconnected the plug (above the interior mirror) and the auto-lights are working correctly again
    But I guess the iffy rain-sensors are also back now too
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Doesn't the rain sensor only work if you push the stalk down? if you push it up your using the standard wiper settings
    13 Post(s)
    Trim : elite
    Year : 2011
    the rain sensor only works wen the wiper stalk is in the
    intermittent position and wen in this position it shouldnt
    wipe unless water has hit the rain sensor.
  1. Auto on lights
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 09:54
  2. Auto lights on / off
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2009, 09:18
  3. Auto on lights
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2009, 23:18
  4. Auto lights
    By phil67 in forum General Chat
    Last Post: 28th April 2008, 09:50
  5. Auto lights not very auto
    By Craig Rogers in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2008, 22:29
lights always on on vectra
vauxhall vectra sri lights permanently on
sigmum auto lights
Zafira b auto lights
how to open vectra c headlights site:www.vectra-c.com
vectra c auto light turn on engine
zafira auto lights problem
opel vectra c auto sensor headlight
opel vectra c auto lamp
opel signum turn off auto lights
sri lights vectra c
vauxhall vectra c light always on
vauhill vectra 2.2 sri headlights come on automatic
https:www.vectra-c.comforumshowthread.php186729-Auto-lights-always-on
automatic daylight opel vectra c
