Results 1 to 10 of 22
Thread: What to look out for. Going to see a car tomorrow night.
    May 2008
    Wiltshire
    Default What to look out for. Going to see a car tomorrow night.
    Hi all.
    Going to have a look at a150bhp 1.9 diesel on an 06 plate tomorrow night.
    What should I look out for on the engine please?
    The car has done 126k
    My last vec c was an 08 in the same engine! But it was a company car.
    Nov 2010
    Maidstone
    Things that spring to mind are
    With engine running slowly depress clutch pedal and listen for a loud clatter as it normally indicates excessive dual mass flywheel wear, cost for repair to clutch/flywheel/slave cylinder are between £500 - £700
    Remove engine dressing and check swirl bar is still on and not coming loose
    Check all coil springs for breaks
    Make sure all lights come and go out correctly as any warning lights are now an mot fail
    Check air con works as vecs/signums are prone for stones piercing condenser/radiator
    Get them to start from cold and check for smoke in first few seconds
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Sticky thermostat, take it a good run make sure it gets to between 85 and 90 degrees, check the swirl valves and make sure the flywheel doesn't rattle on tickover.
    Nov 2010
    Maidstone
    Forgot that one steve
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    -Main things are DMF(dual mass flywheel) listen out for any knocking/banging noise at ide or when the clutch is at biting point.
    -Check to make sure the swirl bar is on and the pots are not dirty with oily gunk.
    -Make sure the cambelt and water pump have been changed.
    -Listen out for any clunking or banging noises when going over bumps as this can indicate warn bushes/parts
    IM sure other members will be able too add things aswell
    Dec 2010
    Glasgow
    Vehicle : 1.9 Cdti Signum
    Engine : z19 DTH
    Mileage : 160000
    Quote Originally Posted by signum_rob View Post
    Sorry to hijack - what would this be showing? is it inlet clogged up, or hole in exhaust side of engine? just wondering?
    THanks
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    it can mean a glow plug(s) are on their way out
    Nov 2010
    Maidstone
    Black/dark grey smoke is quite normal but light grey/white can indicate faulty glow plug/s or like mine a duff inlet manifold.
    May 2008
    Wiltshire
    Question.
    How do you remove the engine dressing? Never needed to open my last bonnet! Being a company car!
    May 2008
    Wiltshire
    Can you also advise where the swirl bar is please?
  1. Replies: 2
    Last Post: 3rd June 2012, 20:38
  2. Anybody fancy a get together tomorrow night?
    By Auto-Brite in forum General Chat
    Last Post: 10th September 2009, 21:17
  3. Last night.
    By Robbie69 in forum The 'Off Topic' room
    Last Post: 12th June 2009, 11:42
  4. Tuesday Night = Labour Night
    By VauxVeteran in forum General Chat
    Last Post: 22nd January 2008, 17:33
  5. yippee top gears back tomorrow night!
    By pogo in forum General Chat
    Last Post: 6th October 2007, 21:52
night car tomorrow 2006
