Results 1 to 3 of 3
Thread: 2 Fault codes with EML and power steering light
    Sep 2012
    Hertfordshire
    Default 2 Fault codes with EML and power steering light
    Hi guys,
    I have an 06 Vectra cdti 150 estate.
    The code information I have is as follows:
    C1532 steering wheel angle sensor -Voltage too high
    P1811 engine torque signal -Malfunction
    I have had a quick search and the steering fault has mixed suggestions as to how to rectify. I believe my alternator is a relatively new one. Am I looking at a new steering rack?
    The second code I have also searched (google as well) and I haven't found much info.
    can anyone help shed light on either?
    Any help would be much appreciated.
    Sep 2012
    Hertfordshire
    Bump.. Anyone? Help? ...
    Regular Member DSmiddy's Avatar
    Jul 2011
    Bridgwater, Somerset
    Engine : 2.8 V6T
    Mileage : 50000
    Hi Baldwin,
    Is your ESP light on? this could point to a problem with the CIM unit (behind the steering wheel) it also has the steering angle sensor built in to it. If the steering angle sensor is faulty it can cause different errors with the ESP, from what iv seen P1811 can be linked to ESP / ABS faults.
    Might be worth getting the CIM checked out, iv also seen a couple of posts about bad batteries causing the P1811 error and a new battery clearing the fault?
  1. Replies: 0
    Last Post: 26th August 2012, 03:15
  2. Fault Codes: Shed Some Light Please?
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2012, 21:39
  3. mil light on three fault codes
    By peter carvill in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 08:44
  4. 1.9 cdti power loss and fault codes
    By Biker in a suit in forum Diesel Engine related
    Last Post: 8th April 2011, 10:42
  5. Emissions Light- Fault Codes
    By Stu_2010 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 21:06
vectra c cdti power steering light on
