Results 1 to 10 of 14
Thread: 2.0T Hose & Dump Valve Exit
    Regular Member Modifications's Avatar
    Sheffield
    Default 2.0T Hose & Dump Valve Exit
    Hi guys, right im looking at getting a special hose made for the turbo which will include the pipe to fit a dump valve. as you know that you have to cut the stock inlet pipe to fit a BOV.
    i have had the kits made before but its not going to be cheap. the last set i had made for my Accord Type R cost £55.00 for just 2 hoses but that was based on 6 kits.
    just not sure if its going to be worth the it thats all. if i can get a few interested i will do the leg work.
    as shown below
    http://forum.vectra-c.com/showthread.php?t=15116
    the one below shows mine installed
    http://www.vectra-c.com/forum/showth...t=13183&page=3
    south yorkshire
    dont do it mate,if your going to fit the bsr kit they dont recommend this as it can upset the air flow meter.not good for the engine as it can start running lean.holed pistons not good either.
    Sheffield
    what the dump valve m8, mine is already fitted bud
    south yorkshire
    yes mate,the standard dump valve on the 2.0t as standard is a recurculating one which is obviously ok,but if you change this for a blow off type eg bailey ect then this might cause you problems especially with the bsr kit fitted.have a look on the bsr web site under faq.hope this helps mate.
    Sheffield
    as long i run the correct spring in the BOV for the PSI it will be fine. i think the standard spring is good for 14psi, anything else i need to change
    south yorkshire
    no mate,its the electronic side of things that this mod causes problems with,because of the air being vented straight out instead of back into the engine.like ive said have a look on the bsr we site this explains everthing mate.
    Sheffield
    you got the link m8 had a quick look and cant see anything
    Sheffield
    ok m8 found it :-)
    well ill see what happens lol
    south yorkshire
    not got a link mate,on bsr web site click on faq then tuning on the list you will see can i fit another dump valve? open this and read on.
    Regular Member Robward27's Avatar
    Witham
    Ive had the dump valve on mine for over 2 years had no problems. Contact forge motorsport they have them there, admittadly though i dont have bsr.
  1. How much for dump valve on 09 VXR??
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2011, 22:25
  2. 2.0 t dump valve
    By stefan7153 in forum Petrol Engine related
    Last Post: 13th May 2011, 10:15
  3. dump valve
    By paulvectrac in forum Diesel Engine related
    Last Post: 6th July 2010, 00:26
  4. Replies: 23
    Last Post: 6th March 2009, 09:00
  5. Dump valve
    By parsco in forum Diesel Engine related
    Last Post: 3rd February 2009, 16:57
