Results 1 to 10 of 13
Thread: Name that hole ??
    Sep 2012
    Crawley
    Vehicle : Vectra SRi CDTi 150 Nav Estate
    Default Name that hole ??
    Been poking about under my 1.9 CDTi 150 today and saw this.
    Should that hole have some kind of pipe connected to it ? It seems to be dripping oil onto the drivers side axle.
    It then runs down to the damaged flexi joint.
    Every now and again I get a load of smoke from under the car, but only for about 30 secs to 1 minute.
    Could this be the oil hitting the flexi joint and burning off ?
    I'd like to know,
    1. What is the thing in the first pic ?
    2. Should it drip ?
    3. Should it be connected to anything ?
    Thanks guys.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    thats you're oil filter and im sure its meant to have a pipe on there
    Sep 2012
    Crawley
    ****** hope not cos I had it serviced yesterday, it hasn't lost a drop of oil in the last 12k miles
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    hmm doesn't look like there's a pipe on there http://www.youtube.com/watch?v=ZSgncIJEtlk see on this vid
    Sep 2012
    Crawley
    Helpful video, thanks.
    Ok so it doesn't have anything connected to it and during an oil and filter change the video says to expect oil to come out of it.
    The car has never dropped oil on my drive so will give it a wipe over and check it again soon to make sure it was only a 'spill' during the service.
    Thanks.
    Apr 2012
    holton le clay
    you are supposed to put a piece of pipe on it so the oil will run into a container and not on your drive or exhaust
    Sep 2012
    Crawley
    Quote Originally Posted by smithysurf View Post
    Yeah I was thinking that would be a better idea. Messy sods..
    Have wiped the worst off now and will take another look next weekend to see if any more has come out.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Exactly what he's said...
    I have a length of garden hose which I use to drain the oil filter at change time. Just loosen the filter until oil comes out of the hole. I think the filter part holds around a litre of oil on its own.
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    I had something similar to this after my service, the second O-Ring was nipped and was letting oil escape out of the drain tube, Remove cap and replace o_ring and you should be ok....
    Regular Member C-Owner's Avatar
    May 2011
    South London
    As already said............... the sealing ring/s have been damaged on replacing the oil filter housing cap allowing oil to pass out of the drain hole.
  1. key hole light
    By slugo in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2011, 23:55
  2. Damage from pot hole
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 27th January 2010, 21:41
  3. A BIG hole
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 15th May 2009, 11:07
  4. Clunk from O/S/F when going over pot hole??
    By Longtallhowie in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2009, 14:40
vauxhall vectra drain holes
vauxhall vectra drain holes site:www.vectra-c.com
