Thread: Fitting Parking Sensors to Rear Bumper and Disconnecting LPG Filler Point
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    236 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Default Fitting Parking Sensors to Rear Bumper and Disconnecting LPG Filler Point
    Hi guys.
    Am due to fit parking sensors this week and will need to remove the rear bumper to do it.
    The question I have relates to the LPG filler point which although a standard type from what I can see, has been drilled and mounted onto the O/S rear bumper.
    The bumper just seems to be "sandwiched" by 2 parts of the filler system, is it really as easy to remove as just undoing the 3 (or 4) visible screws whose heads can be seem clearly when the filler cap is removed ?
    Anyone done this ?
    Woody
    Regular Member squirrell25's Avatar
    Jan 2010
    wednesbury
    Vehicle : SIGNUM 2.0T
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    when i removed the filling point on my old st24 which was lpg'd i lost what remaning gas was in there i was pre warned before hand so i ran to empty before doing it
    can't remember how that one was attatched thouh
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Jan 2010
    wednesbury
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    Quote Originally Posted by troutybrown View Post
    i think woodpeck is going down the oem route which require bonding to the bumper so it as to come off to do them
    May 2012
    236 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Thanks guys, squirrell25 is perfectly correct. Bumper off job for a OEM installation.
    Anyone know about the LPG filler point mount ? Does it literally unscrew with just 3 (I can't remember if it's 3, or possibly 4) screws ? I can't really see a manufacturers plastic bumper being part of the seal arrangements, motre of just a tidy exterior mounting point.
    Woody
    May 2012
    236 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Ah well, Google is being helpful. I've just found this old thread on LPG fitting and it looks reasonably straight forward to reverse the procedure to remove, although it looks like it might be easier to leave it on and just disconnect the LPG pipe.
    Unfortunately, with no ramp / trolley jack and a lowered car, it doesn't look that easy to tackle so I guess it will have to be done at a garage or possibly an LPG fitting centre.
    Anyway, I'm wiser now than I was but if anyone has anything to add, please feel free.
    Here's the old Omega Forum thread in case anyone else ever has a similar issue to address.
    http://oldsite.omegaowners.com/forum...m=1270405395/0
    Sep 2012
    Stoke on Trent
    Engine : 1.9 CDTi 150 Z19DTH
    Malcolm, just close the valve on your LPG tank and undo the nut attaching the pipe to the filler point.
    Use PTFE tape suitable for gas appliances when refitting. Should be easy enough.
    Sep 2012
    Stoke on Trent
    If it is a pig to get to try taking your diffuser off.
    May 2012
    236 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Yeah, I saw that fella, but without a ramp / trolley jack and with the car lowered as much as it is, I can't get under it sufficiently well enough to see, plus with it being LPG I wouldn't want to risk it. The old thread I posted shows what's involved, but space & access is the problem now mate.
    I'm due a LPG service at a fitting centre soon because they had to cancel my last appointment. I think I'll just turn up in person to re-book and ask them to disconnect the pipework while I'm there and get it re-fitted later.
  1. fitting aftermarket rear parking sensors , best way to get into boot?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 11:08
  2. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  3. Replies: 5
    Last Post: 5th February 2012, 20:42
  4. fitting aftermarket rear parking sensors
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 19:45
  5. Fitting rear parking sensors to Honda jazz ..HELP!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2008, 10:54
