Results 1 to 3 of 3
Thread: Signum rear trye/bearing/usual? Noise
    Derby
    Default Signum rear trye/bearing/usual? Noise
    Have recently got a 2006 Siggy and getting a quite annoying noise from the rear. Difficult to describe but to me it does sound like tyre noise, more noticeable on Motorway and increases with speed, breaking into medium pitched harmonics a bit like you would hear from a lift motor. I am wondering if it is usual from this car due to its slightly more "open" design at the back, its way more noisy than my 2002 Vectra was, or if it could be bearings/tyres. There doesn't seem to be any play in the bearings. The rear tyres will need replacing soon, maybe the low level of tread is not helping?? Anyone any good recommendations for budget-ish quiet running tyres?
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Mazda 6
    Trim : SE L Lux Nav+
    Engine : 2.0 Skyactiv-G
    Year : 2019
    If the tires need replacing, best to get mid range to premium tires. Safety is more important than saving money, as the tires is the only safety net between you in the car and being in a ditch. When it comes to tires i would go for Falken or Avon.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Try moving the rear tyres to the front and see if the noise moves to the front... then move them back until you get them replaced.
  1. signum..grinding noise from rear
    By uaintsinme..right in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2009, 21:47
  2. Strange Noise from Signum Rear End
    By powelly1592 in forum Suspension, Wheels & Brakes
    Last Post: 4th May 2009, 01:34
  3. signum rear wheel bearing
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 20:03
  4. signum rear wheel bearing
    Last Post: 17th June 2008, 19:46
  5. noise from rear of signum
    By mike56 in forum Suspension, Wheels & Brakes
    Last Post: 9th February 2008, 14:29
