Thread: Can 'spanner' light inidcate service over-due
    Regular Member 1-8clusive's Avatar
    Jun 2009
    sheffield
    Default Can 'spanner' light inidcate service over-due
    Hi,
    My Vectra 1.8vvt (58 reg) has been due a service for a few weeks and as usual the 'insp' text came up on the trip-meter however due to work issues I couldn't get it into the garage straight away and after drivng with 'insp' coming on for a week to 10 days (around 700 miles) the engine electronics light (spanner) came on and has stayed on. Is this a warning that the service is late or is it a totally separate fault. Car was still running perfectly and fuel economy fine despite the light.
    Local garage has now serviced the car and mentioned the light but said the error code wasn't one they recognised. This was 80,000 miles service and car has never had an error before.
    thanks,
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Year : 2003
    Mileage : 75 000
    The spanner indicates a real fault.
    If the garage is unable to identify the code, maybe you should ask a more competent person, even someone on the forum living in your area.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    What was the code? Did they reset it? has it come back on?
    Jun 2009
    sheffield
    I didn't get the code, maybe should have probed them a little bit more. They reset it and the light hasn't come back on and car drives fine.
    Regular Member taffy bhoy's Avatar
    newport
    does the pedal test work on the 1.8vvt to get the code yourself?
    Jun 2009
    sheffield
    I tried the brake / accelerator Ignition routine and it doesn't seem as if any code is stored, probably removed during the reset? . I think I will just have to keep an eye on things and hopefully it won't come on again.
  1. Service Spanner/Oil Can on my dash!
    By VXR CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2013, 14:42
  2. loss of power / service spanner light
    By cookie01 in forum Engine & Drivetrain
    Last Post: 9th August 2011, 11:11
  3. spanner light on after engine service
    By bensdad2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th September 2010, 10:39
  4. spanner / service / Insp
    By bobby_rstevens in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2008, 22:03
  5. spanner light on after service.
    By zeadly in forum Engine & Drivetrain
    Last Post: 31st July 2007, 16:05
