Thread: Misfire @ 1800rpm
    Nov 2012
    Essex
    Default Misfire @ 1800rpm
    My car is an '04 1.9 CDTI
    Runs fine throughout the rev range other than when it hits 1800rpms. Then the engine judders, the car lurches back & forth. Rev higher or lower & it's fine.
    What might cause that?
    Aug 2012
    South Wales
    Mine the same mate especially when pulling hard done loads but still no joy what have you done to it so far ie clean egr boost sensor etc
    Jul 2012
    Ireland
    Ye mines same too. Cleaned EGR, cleaned throttle body, checked pipes, took out the gauze from boost sensor. Still the same. What else is there to do. It's a doing it nearly a year now.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Is it a mis-fire or a flat spot? The CDTI is notorious for the flat spot... where power drops off then kicks back in
    LEDBURY
    ive had this issue for about 6 mths, mine is 1.9 cdti 150 16v. ive replaced manifold egr boost reg its been full serviced the lot even the injector wiring on all 4, not sure what else now runs fine other than 1800-2000rpm this hesitation any ideas would be would be very welcome. cheers in advance.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    This seems pretty common. Mine does the same, only at about 2000 rpm and only on light throttle settings - if I put my foot down it runs smoothly. It's not a flat spot but more of a judder.
    PS: Replaced EGR valve (and tried it blanked and unplugged), cleaned throttle body, replace boost sensor and solenoid thing.
  1. CDTi-150 Flat Spot @ 1800rpm
    By Signum7060 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2012, 07:27
  2. 3.2 misfire
    By noudder72 in forum Engine & Drivetrain
    Last Post: 29th November 2011, 23:05
  3. ****** misfire still!
    By johnnylegs in forum Engine & Drivetrain
    Last Post: 18th August 2011, 18:26
  4. low power above 1800rpm eventually resulting in LHM
    By zerocool in forum Engine & Drivetrain
    Last Post: 30th May 2011, 00:19
  5. 2.0 dti misfire
    By Micknal in forum Engine & Drivetrain
    Last Post: 30th September 2009, 17:15
