Results 1 to 10 of 19
Thread: Gunson Eezibleed
    Nov 2010
    Maidstone
    Default Gunson Eezibleed
    Just wondered who has used this bit of kit, was reading reviews on halfords website and in 2 minds now. Any input welcome.
    "This is a very good idea and concept, however, the problem is the fact that it relies in the air in the tyre. Alas, one thing you will note that when even you fill up air particularly from an air line at a petrol station, is that the propelled air has a lot of mositure! The reason you are changing/bleeding the brakes is because brake fluid is hydroscopic, i.e it absorbs water which leads to corrrosion and problematic brakes. So you are actually propelling the fluid with a high percentage of water contamination, so failed at the first hurdle."
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Spot on bit if kit mate
    Nov 2010
    Maidstone
    I did think to myself there cant be much moisture released from a tyre that would contaminate the braking system.
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    19 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    I've had one of these for years, fantastic bit of kit, can't fault it!
    Regular Member Keif's Avatar
    In the Garage
    I have one too and as everyone else has said, brilliant bit of kit.
    The only thing you need to make sure of is the tyre you use to pressurize it, is not above 14psi (IIRC) as you can blow piston seals.
    As for moisture..... you've hit the nail on the head with your above reply.
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Use one of these for the first time this week, and it made the job so easy. Got mine from amazon next day delivery for £16.00. I used a spare wheel barrow tyre that was at 11PSI Bottle says "max 20 PSI" but better to be safe.
    Regular Member Dennisd's Avatar
    Oct 2010
    Netherlands
    Trim : Sport
    Engine : 1.9dth
    Mileage : 92000
    A good piece of kit, i used it last year when i did my 314/292 conversion, can't fault it.
    Regular Member LGaffer's Avatar
    Dec 2012
    Castleford
    5 Post(s)
    Vehicle : Vectra C Preface
    Trim : SRI
    Engine : 1.9 cdti 150
    Yeah , definately a good piece of kit. I've used mine loads of times and never failed me. Easy to use!!!!!!
    Regular Member paul.sessions's Avatar
    leighton buzzard
    Worth it mate makes the job a lot easier.
    Nov 2010
    Maidstone
    So if the kit requires a max of 20 psi, might have to nip down the petrol station and use the digital pump to lower spare pressure, might have to invest in one of these.
  1. Gunson Eeezibleed
    By conman in forum Handling & Braking
    Last Post: 14th December 2012, 20:05
  2. Cap/Seal combo - Gunson Eezibleed
    By snapsnap in forum Handling & Braking
    Last Post: 26th November 2009, 13:52
  3. Gunson 4142 dwell angle connections - HELP
    By Ste in forum General Chat
    Last Post: 31st January 2008, 16:52
