Hi I've just driven a signum 3.0cdti auto and it pulls like a train the only problem I think it's got is that when I easy of on the throttle the cars revs just drop to idle is this normal.
Hi fella, your revs will vary according to the gear that your auto gearbox is using and the speed you are driving at versus how much throttle you are giving it and the load on the car at the time.
If you easy off on the throttle, you will likely find yourself in a higher gear than the one in use when you were "pulling like a train".
Are there any warning lights on the dash, or spanner light even ? If so, just get the codes read by some helpful local member and post the details on here![]()
It's normal.![]()
No warning lights on dash, but I noticed that above 50mph it holds it's revs and doesnt drop to tick over.
