Results 1 to 10 of 15
Thread: Went mad with my LEDs
    Regular Member spikeyboi33's Avatar
    Jan 2013
    Ireland/Poland
    Vehicle : Vectra C Prefacelift.
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Default Went mad with my LEDs
    Got a strip of LEDs in the post today so decided to fit them, hooked them up to the ciggy lighter but i think thats temporary, because i want them on when the speedo illumination is on so that it turns on whenever i unlock the door or open them or turn on the lights. Anyone done the before this way? would appreciated info on where to hook them up :P
    Zdjęcie0490 by SpikeyBoi33, on Flickr
    Zdjęcie0489 by SpikeyBoi33, on Flickr
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    You can do them to the interior light so fob activated and doors open etc... Or use the yellow/grey dash feed wire, again fob but light switch activated and will dim with the dimmer... I wouldn't want them on all the time however, I did mine to the interior light, white/brown & brown wires in the interior light block
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Quote Originally Posted by leemarksmith View Post
    Thanks for the help, but what you mean by the dash feed wire? the wire that goes to the light switch?
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Sorry meant the dash LED feed, for illumination... Its the yellow/grey wires and there's various ones around, cig lighter may have one, blocks behind the dash, you may even have wires under the arm rest where some have the wires for rear heated seat blocks
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    oh i see what you mean, thats great thanks a mil man
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    No problem
    Regular Member Manos_GTS's Avatar
    GREECE
    i have another problem with mine led's! i bought those http://www.ebay.co.uk/itm/Vauxhall-V...item4841f65d7b
    i fittied them the were good! so i left the car and locked it! tha same dey in the night i went to the car and i saw the led's flickering o start up and the dashboard weren't lighting at all! o thought that maybe is the fuse box... any ideas?
    Regular Member hairytimes's Avatar
    Apr 2012
    norwich
    Sounds like some dodgy wiring tbh mate
    GREECE
    sory but i didn't underastood what you mean with "dodgy wiring tbh"
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    What he meant is that you might of wired it up in a way that could give you shortages that could in turn blow fuses and other things, for example not soldered together, no heatshirnk or electrical tape around the connections which then touch of each other creating shortages. Have a look back at your wiring make sure everything is hooked up nice and secure, especially if you're twisting and taping your connections.
  1. leds where from.
    Last Post: 12th December 2012, 09:19
  2. Which LEDs
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2012, 23:00
  3. LED conversion, How Many LEDS, Which LEDS
    By gurjsagoo in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2012, 20:44
  4. LEDs
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 15:42
  5. LEDs nearly done
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 23:48
