Thread: clutch slipping?
    durham
    Trim : Leather
    Eek clutch slipping?
    help, my 2005 v6 diesel with tuning box fitted has developed clutch slip, when driving in 4th 5th or 6th gear when i floor it at 2 thousand revs the tacho jumps to 3 thou without going any faster, then the clutch seems to get hold again and everything is ok till the next gearchange then it happens again. it seems as though this is happening as the car comes on boost and is making all the bhp hence a weak clutch will let go at this point, has anyone else had this problem ? the car only has 20thousand miles on is under network q . is the clutch covered ? help
    Regular Member Modifications's Avatar
    Sheffield
    hi m8, take the tunning box off and then try it. have seen many posts on the 2.0T ( same as saab models ) having the same problem when having the BSR map.
    but when they took the map off the clutch was fine so it would be hard to get it covered under the warreny as it only does it when the BSR map was running.
    seems to me that the VX clutches are only good on stock BHP etc.
    durham
    Trim : Leather
    thanks for the reply, i will try that and let you know what happens
    Sheffield
    if it does slip without the box then you should be in luck
    Feb 2007
    Timisoara
    I had the same problem. Solution? Replace clutch disc. It had worn down. Now it's like flying.
    Regular Member dervdoc's Avatar
    Co.Armagh
    also sometimes when clutch goes flywheel needs replacing
    durham
    Trim : Leather
    took the box off and guess what no clutch slip, typical. well the box is staying off for good now, its a lot slower but hey what the hell at least my tyres will last a bit longer.
  1. New Clutch Slipping
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2012, 02:56
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Slipping clutch
    Last Post: 23rd December 2008, 19:09
  4. Slipping Clutch
    By kel123 in forum Engine & Drivetrain
    Last Post: 12th July 2008, 11:16
  5. clutch slipping
    By carl bear in forum Engine & Drivetrain
    Last Post: 10th May 2007, 14:08
