Results 1 to 10 of 16
Thread: Help with Diagnostics report Please
    Regular Member Al 150 cdti's Avatar
    fareham hampshire
    Engine : 1.9cdti 150
    Question Help with Diagnostics report Please
    **********************ECU ID STARTS**********************
    Source Address: CIM
    Source Address: 0x00000245
    Identifier: 0x0015
    VIN:
    Part Number:13204146
    Software version number: 12244872_
    System description: DELPH0400
    Hardware key number: *27HELD
    Alpha code:
    Manufacturing date: 060822
    Code Index and version: 008 02
    Number of stored fault codes: 6
    B3794 - Switch Cruise Control Circuit Malfunction
    (08) - Not present
    U2103 - No Communication with CAN-Bus (High Speed)
    (00) - Not present
    U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
    (00) - Not present
    U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
    (00) - Not present
    U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
    (00) - Not present
    U2120 - CAN-Bus No Communication with AHL (Headlamp Levelling Device)
    (00) - Not present
    **********************ECU ID ENDS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x0758
    System name: Z19DTH
    VIN:
    Hardware number:81013408
    Part Number:55205633
    Software version number: WJKMS070_S
    Hardware manufacturer number: 0281013408
    System description: 1037379428P319_O90
    System description: BOSCH0100
    Type approval number: B04003
    Programming Date: FFFFFFFF
    System description: 0x00006098
    Alpha code: ET
    Software version: O90JTD75
    ECU variant coding: 0x00003980
    Number of stored fault codes: 9
    P0070 - Ambient Air Temperature Sensor Malfunction
    (74) - Not present
    U2108 - CAN-Bus no Communication with ABS/TC
    (70) - Not present
    P0500 - Vehicle Speed Signal Range/Performance
    (7E) - Not present
    (7F) - Not present
    U2103 - CAN-Bus Circuit Malfunction
    (08) - Not present
    (06) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (7F) - Not present
    P1815 - Cruise Control Interface Malfunction
    (72) - Not present
    (70) - Not present
    Source Address: ABS/TC/ESP
    Source Address: 0x00000243
    Identifier: 0x6003
    System name: ABS 430 NG
    Hardware number:0
    Part Number:12773671
    Software version number: 00C2E92D
    Alpha code: BS
    ECU variant coding: 0x00001918
    Number of stored fault codes: 3
    U2103 - <Unknown DTC>
    (00) - Not present
    U2105 - <Unknown DTC>
    (00) - Not present
    U2139 - <Unknown DTC>
    (00) - Not present
    Source Address: EHPS
    Source Address: 0x00000244
    Identifier: 0x0104
    System name: EHPS GEN3 TRW
    Hardware number:24444336
    Part Number:0
    Software version number: V21_
    System description: TRW 0300
    Alpha code:
    Code Index and version: 009 03
    ECU variant coding: 0x00000000
    Number of stored fault codes: 4
    (00) - Not present
    U2105 - CAN-Bus no Communication with ECM (Engine Control Module)
    (00) - Not present
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    (00) - Not present
    Source Address: AHL/AFL
    Source Address: 0x00000249
    Identifier: 0x0410
    System name: AFL_Z3220
    Part Number:13184052
    Software version number: 60.05.01.01
    System description: VALEO0400
    Manufacturing date: 20060124
    Code Index and version: 002 06
    (71) - Not present
    U2100 - <Unknown DTC>
    (00) - Not present
    (00) - Not present
    (00) - Not present
    (00) - Not present
    U2143 - CAN-Bus No Communication with SAS (Steering Angle Sensor)
    (00) - Not present
    Source Address: IPC
    Source Address: 0x00000255
    Identifier: 0x1103
    VIN:
    Part Number:13193080
    Software version number: 3.40 10/05
    System description: VDO 0400
    Hardware key number: 0000000000
    Alpha code: QW
    Manufacturing date: 060821
    Code Index and version: 004 05
    (7F) - Not present
    (7F) - Not present
    (7F) - Not present
    Source Address: AIRBAG SDM
    Source Address: 0x00000257
    Identifier: 0x0102
    VIN:
    Part Number:13186947
    Software version number: 0C0D4B11
    Alpha code: KN
    Number of stored fault codes: 1
    U2139 - Invalid Data from CIM (Steering Column Module)
    (7F) - Not present
    Source Address: ECC
    Source Address: 0x00000248
    Identifier: 0x0301
    VIN:
    System name: SAC 3220
    Hardware number:13166480
    Part Number:13166481
    Software version number: 0ZF00/25C61
    System description: BHTC 04
    Alpha code:
    Manufacturing date: 20060904
    Code Index and version: 002 02
    No fault codes stored.
    Source Address: BCM
    Source Address: 0x00000252
    Identifier: 0x0209
    VIN:
    Part Number:13193590
    Software version number: D02D11 49041605
    System description: TEMIC04
    System description: 0x20202020202020303031353335323136
    Alpha code: NF
    Manufacturing date: 000600080206
    B3916 - No Communication With Alarm Siren
    (0F) - Not present
    Source Address: REC
    Source Address: 0x00000254
    Identifier: 0x0105
    VIN:
    System name: REC
    Part Number:13205774
    Software version number: 00000FA1
    System description: LEAR 0400
    Alpha code: FP
    Source Address: UEC
    Source Address: 0x00000253
    Identifier: 0x0105
    VIN:
    System name: UEC
    Part Number:13240244
    Alpha code: JF
    Source Address: DDM
    Source Address: 0x00000259
    Identifier: 0x0106
    VIN:
    Part Number:13193368
    Software version number: OP1D 193000
    System description: SIEM 0401
    Hardware key number: XXXXXXXXXX
    Alpha code: JQ
    Manufacturing date: 328060
    Source Address: PDM
    Source Address: 0x00000258
    Identifier: 0x0105
    VIN:
    Part Number:13193369
    Software version number: OP1D 192000
    Alpha code: JR
    Source Address: EHU
    Source Address: 0x00000241
    Identifier: 0x0504
    System name: CDC 40 OPERA
    Hardware number:13188432
    Part Number:13188475
    Software version number: 09.05/-----
    System description: BOSCH0400
    Alpha code: LN
    Manufacturing date: 20060829
    Code Index and version: 023 01
    Audio Index and version: 043 03
    Source Address: DIS
    Source Address: 0x00000246
    Identifier: 0x1201
    VIN:
    System name: CID/GID Epsilon
    Hardware number:13128260
    Part Number:24461295
    Software version number: GE59-/00050
    System description: SIEM 0400
    Alpha code: DD
    Code Index and version: 002 01
    Number of stored fault codes: 2
    (71) - Not present
    U2201 - CAN-Bus No Communication with EHU (Entertainment Head Unit)
    (00) - Not present
    Source Address: EHS
    Source Address: 0x0000024D
    Identifier: 0x0101
    System name: DAB 45
    Hardware number:13111066
    Part Number:13111066
    Software version number: 01.33/rel60
    Alpha code:
    Manufacturing date: 20060818
    fareham hampshire
    Previously all Cleared, showing no problems with running, other than a slight power drain. engine z19dth 150
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Have you put a meter across battery
    South east
    Quote Originally Posted by Al 150 cdti View Post
    Do you mean a drain on the battery when the engine is off, or a lack of BHP when running?
    fareham hampshire
    battery all fine, readings perfect, sorry should have explained more. e.g when turning the steering wheel at slow speeds the centre display (radio-mpg-settings) that one, goes dull then comes back like the power is being drained. troubling me
    fareham hampshire
    Bump
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Clear codes an see what returns.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    early signs of alternator failing me thinks does anythin else go dim
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    How dull or just dim slightly
    The current draw by power steering is very high.
    so put a lot of strain on alt when at low speed
    fareham hampshire
    very dim then brightens back up, parking in tight spaces and slight judder from steering wheel when turning into tight spaces. Alternator was replaced year and half ago with battery at the same time. display disappears almost when auto levelling headlights are on. would the a wrong alternator amp cause this?
  1. Diagnostics
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 03:08
  2. Diagnostics
    By neill in forum North West (RO - bonehead, ARO Woody
    Last Post: 10th April 2012, 19:55
  3. been to vx for diagnostics :(
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th March 2011, 20:33
  4. VW Diagnostics
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 29th April 2009, 09:33
