Thread: Urgent help needed
    Apr 2013
    corby
    Vehicle : Vectra 2.2
    Trim : ls
    Engine : 2.2
    Year : 52
    Default Urgent help needed
    Hi I've got a problem with my 02 2.2 vectra. I've been having some problems with it being sluggish so thought I'd give the throttle body a clean as it looked a bit soiled. Once I cleaned it the car now won't start it try's too but just won't kick in. The petrol light keeps going funny aswell now says there's no petrol in it then its back up to quarter again. Anyone have any ideas
    Apr 2013
    corby
    Trim : ls
    Engine : 2.2
    Year : 52
    I can now get the car to kick in now and again but revs shoot up too 4000 and idles at that. Anyone help yet
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    did you clean through the pipes/tubes going into the TB as well....?
    Apr 2013
    corby
    Trim : ls
    Engine : 2.2
    Year : 52
    Yeah both done cleaned through the small pipe to the rocker with a bottle brush. Is there a sensor on the throttle body? As took one off while I cleaned everything I've put it back but thinking maybe its sitting wrong ill find picture
    Apr 2013
    corby
    Trim : ls
    Engine : 2.2
    Year : 52
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Matt, your pic is from an ebay sale http://www.ebay.co.uk/itm/VAUXHALL-V...-/280979820199
    so as you are already aware its a TPS (throttle position sensor) for Z22YH engine..
    The problem you describe do sound like a TPS fault, if you check your fault codes the TPS will more than likely be giving you an fault code if it is at fault.
    Apr 2013
    corby
    Trim : ls
    Engine : 2.2
    Year : 52
    Yeah I know that's where I found the picture. Ill see if I can get someone to get the codes
    Apr 2013
    corby
    Trim : ls
    Engine : 2.2
    Year : 52
    still got the problem all the car will do is turn go to fire up and die. Could it be the coil pack or spark plugs not giving it a spark? think im just clutching at straws
    Does anyone have any ideas need to get the car back running
    Apr 2013
    corby
    Trim : ls
    Engine : 2.2
    Year : 52
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Have a look at the Z22SE forum if no luck here then report back, I'm stripping my 2.2 later but its the YH as its 05, kid I bought it off reported similar till eventually it wouldn't start, will let you know tonight if I solve my issue...
  1. Urgent Help Needed...
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2010, 23:54
  2. Urgent help needed
    By jlock in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 14:12
  3. urgent help needed!
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 11:12
  4. urgent help needed
    By julls in forum The 'Off Topic' room
    Last Post: 10th March 2009, 14:06
  5. urgent help needed!!!!!!!!!!
    By johnnyg in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2008, 14:29
