Results 1 to 10 of 23
Thread: Cut through HD power extension cable. Can it be joined again?
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default Cut through HD power extension cable. Can it be joined again?
    Hi all
    I just bought a 45m power extension reel and stupidly cut through it yesterday when trimming the hedges.
    I have lost about 10m of cable and wonder if its possible to join it again. I have rewired the plug so the reel works fine but I don't want to loose the 10m or so I chopped off if it can be helped.
    If possible what would be the best way to do this.
    Many thanks
    Chris
    P.S This is the one I bought
    http://www.diy.com/nav/fix/electrica...skuId=11039600
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Simple answer, yes. However, doing it safely and properly will put a short 'less flexible' section in the cable. It's simply a matter of jointing both ends, heatshrinking the individual conductors then the overall cable at the repair point.
    Overall length lost should be all of around 30-50mm.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thats good to hear. Thank you
    Should I solder the three inner cables together or is there a better way to join them.
    Sorry if im asking stupid questions.
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    Solder the individual cables together but make sure its a good join to ensure it doesnt come apart later when the cable is pulled.
    Heat shrink the individual cables, and then either heat shrink the lot or just get the outter part of the damaged cable to cover it up or use a bit of a hose pipe or similar. then cover with electrical tape.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks very much all. Off now to get some different sizes of heat shrink.
    13 Post(s)
    When soldering the 3 separate wires, keep the joins staggered from each other and not right next to one another.
    1. It'll make the join less bulky.
    2. Less chance of the wires shorting against one another if the heat shrink moves or chafes through.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks Dave. Good idea. Will do that
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    IMHO, joining the 'cut off' piece back on is a bad idea. It wont stand up to much winding and unwinding. In a professional environment i.e. having to be pat tested, this would most likely be a fail (i'd fail it). I personally would buy a single trailing plug and or socket and make a seperate 10m extension to add to the 35m one should you require it.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by BigWilko View Post
    Hmmmm your logic makes sense and has got me thinking now. All the unwinding and winding back in again would probably break it.
    I will just go and get another extension to extend it.
    Lesson learnt the hard way. Keep them cables out of the way of the hedge trimmer
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    dont join it i woukd also fail it solder isnt a proper join for any 240v
  1. Amp power cable
    By vermiculus-daemon in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 15:55
  2. Power cable to amp, easy to route?
    By sdnatlst in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2010, 16:44
  3. AMP power cable trough motorhood??
    By vectralex in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 13:57
  4. power & cable poliser ( PC )
    By ian_c in forum Detailing and Car Care Discussion
    Last Post: 18th March 2006, 14:03
