Thread: 2.2 direct running rich
    Mar 2013
    south wales
    Vehicle : Vectra C facelift
    Trim : sri
    Engine : 2.2 Direct
    Default 2.2 direct running rich
    My 2.2 direct is giving bad mpg after having a service ( oil ,filter, plugs, tb cleaned) but is still only getting 26mpg combined. I had my friend put it on opcom and no faults but it was saying that it is running rich and the air intake is showing 32degrees when its 10degrees outside. No management lights on and driving fine but Could it be the maf? Or lambda?
    Regular Member Lordish's Avatar
    Feb 2012
    Luton
    The maf is easy to clean. Front lambda is easy to change. The rear one is tricky. I had a faulty rear lambda so mine was running rich. Around late 20's mpg. Changed the rear one and sorted. Bit it did show an O2 fault on opcom.
    Mar 2013
    south wales
    Trim : sri
    Engine : 2.2 Direct
    Thats what i cant understand? No faults what so ever and runs fine? Dont want to buy lambdas and maf and spend a fortune to not fix the problem?
    Feb 2012
    Luton
    Maybe it needs a better diagnostic done. Tech 2 or the dealers or something.
  1. Car's running RICH *HELP*
    By Mark Evison in forum Engine & Drivetrain
    Last Post: 7th August 2012, 22:22
  2. Running rich ?
    By tosh23 in forum Engine & Drivetrain
    Last Post: 17th August 2011, 21:31
  3. Help!! car running Rich low MPG Diagnostic report inside
    By tattootroy in forum Engine & Drivetrain
    Last Post: 23rd July 2010, 02:08
  4. 2.2DTi running rich ?
    By Daywalker in forum Engine & Drivetrain
    Last Post: 19th September 2009, 13:25
  5. 2.2 Sri Direct - running rough
    By johnmac in forum Engine & Drivetrain
    Last Post: 24th December 2007, 19:12
vectra 2.2 running rich
