Results 1 to 2 of 2
Thread: inlet manifold
    Regular Member crofty76's Avatar
    worksop
    Default inlet manifold
    would a siezed inlet manifold and loose swirl bar cause car not to start and wen it eventually does run with a flat spot ie no power under foot sumtimes and cause black smoke wen accelerateing advice would be great cheers guys
    West
    I wouldn't think it would cause none starting issues... it will cause poor running if the flaps are stuck closed... search the forum, as a temporary measure don't bother trying to put the bar back on, aim the top of the flaps into the 10 o'clock position & glue them in place. unplug the egr, then use carb cleaner in the inlet while someone holds the revs down... this will clear a lot of crud. then go for a good motor way run.
  1. inlet manifold
    By chay6684 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 23:24
  2. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  3. Inlet manifold what do I need
    By sebadee in forum Engine & Drivetrain
    Last Post: 6th March 2011, 00:41
  4. Inlet manifold
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2010, 17:26
  5. Gsi 3.2 inlet manifold.
    By gromit in forum General Chat
    Last Post: 13th October 2009, 10:09
