Thread: Tyre size slight difference
    Regular Member GSiMrG's Avatar
    Mar 2012
    Harrogate
    Default Tyre size slight difference
    Sooo......
    i have the chance if some 225/40/18 toyo proxes......
    The tyres I have at the minute are 225/45/18.
    Would this change the ride or should I stick to 45's
    (xp2 wheels)
    Regular Member spikeyboi33's Avatar
    Jan 2013
    Ireland/Poland
    Vehicle : Vectra C Prefacelift.
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    a small difference in comfort is all and slight change in speedo readings
    Dec 2011
    Seaham
    Use this tyre size calculator to see how much difference it will make to the speedo etc.
    http://www.etyres.co.uk/tyre-size-calculator
    Sep 2010
    an inch difference in overall diameter. I wouldn't but horses for courses.
    Dec 2011
    Seaham
    Try Asda tyres, you may get a better deal? I have just used them and they are fitted at a local garage, just enter your postcode. They were much cheaper then Blackcircles etc
    I have just fitted some Sailun Atrezzo's, they have very good ratings for Wet Grip, noise and wear, your size comes in at £70.60 fitted!
    Mar 2012
    Harrogate
    These are free
    Dec 2011
    Seaham
    Well fit them, just be aware that your speedo with over read (e.e. speedo reads 60, you are actually doing 58) and you may have a slightly harsher ride due to the reduced profile.
  1. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  2. tyre size
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 9th November 2011, 20:12
  3. tyre size
    By chris1804 in forum Handling & Braking
    Last Post: 12th June 2011, 21:37
  4. tyre size
    By kevin hunter in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2008, 20:58
  5. What a difference a tyre makes.
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 19:54
