Thread: Front windows
    Regular Member spikeyboi33's Avatar
    Jan 2013
    Ireland/Poland
    Vehicle : Vectra C Prefacelift.
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Default Front windows
    Bit of a ****** this, my front windows wont lose or open automatically as in you press the button leave go and they go down or up by themselves. rears do that fine but the fronts don't. also when you try the trick with the key fob, as in when you press the lock or unlock button for few seconds and all the windows go up and down aswel, that wont work on the front neither. it did few days ago:S
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    you need to reset the limit switches. hold the driver door buttons down for 10 seconds in the direction they're already in (i.e. hold it down when the window is down then up when the window is up). Can't remember whether it beeps of not though.... then repeat for the other side window
    Regular Member Keif's Avatar
    In the Garage
    To reset.
    Press the window down switch, and hold for 2 seconds after the window has got to the bottom of it's run.
    Then press the window up switch, and hold for 2 seconds after the window has got to the top of it's run.
    Repeat for the other side.
    Job done.
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    worked like a charm, thanks guys
    New Member underzz's Avatar
    Mar 2013
    Ireland/Latvia
    Trim : C
    Engine : 1.8
    Year : 2002
    Mileage : 97k
    Thanks,guys.Worked for my car too.Again thanks
    Feb 2011
    Selby
    It does say all this in the owner's manual you know...
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Looks like im a lazy b*****d
    but seriously, i had no idea
    Nov 2012
    Denmark
    6 Post(s)
    Vehicle : Opel Vectra
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    as said, it's in the manual. Doesn't mention anything about holding the switch when windows are open. Ignition on, open windows fully, close window and hold for 3 sec.
  1. Front Windows Dropping
    By Sparky67 in forum Bodywork & Interior
    Last Post: 9th January 2012, 22:13
  2. Front Windows
    By Tinners in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2011, 01:11
  3. Electric front windows
    By ianm59 in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2010, 16:54
  4. Electric windows (Front)
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 23:40
  5. Front Windows
    By sb1uk in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 14:02
cant open windows with remote on vectra c
