Thread: Z30DT Throttle body
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Default Z30DT Throttle body
    As I didn't mean to hijack another thread with my query, I thought I would start a new one.
    when I looked at my throttle body when cleaning the pipes, so to speak! I noticed that it was wide open when the engine wasn't running.
    This can't be right, can it? every other car I have owned in the past (albeit petrol) the butterfly flap on the throttle body is always closed when engine not running. apart from a small gap. but not on my Vectra, Wide open!
    Jan 2013
    Finland
    Same here.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I don't know if the Z30DT flap is electronically controled but on my Y30DT it makes a hiss and the flap closes.
    Oct 2009
    Bilbao&Madrid
    Trim : Cosmo
    Engine : 3.0 CDTI Z30DT
    Obviously the intake throttle valve in a petrol engine performs a very different role than in a diesel engine. I guess that the fail-safe position of the throttle valve in a diesel engine is to maintain it wide-open, whereas in a petrol engine it is slightly open to allow it to idle.
    We regulate a non-direct injection petrol engine by opening and closing the throttle valve, thus allowing more air into the manifold (which will be mixed with fuel at a fixed air to fuel mass proportion: 14.7 tons of air per every ton of petrol). So we control the quantity of air-fuel mix by means of the throttle valve (it cannot be fully closed or no air can enter the engine, it cannot be fully open at idle, so the fail-safe position in case something fails is to maintain it slightly open).
    We control a diesel engine by varying the quantity of fuel (only), so the air intake path doesn't usually need throttling. This valve is used here to either bypass the intercooler and increase the intake air temperature (for a DPF regeneration), or to decrease the amount of fresh intake air entering the engine (by throttling it in a diesel, for a change) with the aim of increasing the EGR rate without recirculating so much exhaust gas into the engine. So if the valve fails, the safest position which allows the engine to work is wide-open throttle.
    (I hope it didn't sound too pedantic)
    Feb 2011
    Worcester
    Thank you yoladeuche! you weren't coming across as pedantic at all, but very informative! thank you very much.
    Oct 2009
    Bilbao&Madrid
    Trim : Cosmo
    Thanks, although it seems my memory has mixed the facts a bit regarding its functions in a diesel. The exact mechanism used for EGR is to create a vacuum in the intake manifold (to increase the flow of exhaust gases), and the thing about DPF regeneration is not performed by "regular" throttle valves like the one in the first link:
    http://delphi.com/manufacturers/auto...ontrols/dmvrv/
    http://delphi.com/manufacturers/auto...ontrols/ddetc/
    What I didn't know is that they are also used to smooth engine shutdown.
    Sep 2013
    bucharest
    Vehicle : vectra c
    Trim : speedline 18
    Engine : z30dt
    Year : 07
    "So if the valve fails, the safest position which allows the engine to work is wide-open throttle."
    so when the engine runs on idle the flap must be wide open?
    I try to close it using a Tech2 and the engine sound is much better but after a few sec the flap open again
    what is the correct position ?
  1. z30dt Throttle snatchy/jerky
    By stoph in forum Y & Z30DT Specific
    Last Post: 28th July 2012, 06:35
  2. 1.9 tid 150 Throttle body
    By Paddy in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 22:30
  3. oil in throttle body help
    By drivs in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 19:13
  4. Throttle Body
    By vectraestate in forum Engine & Drivetrain
    Last Post: 25th March 2010, 17:33
  5. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
z30dt throttle
vectra c 3.0 cdti throttle body
vectra c 3.0 throttle body
throttle body for Z30dt engine
z30dt throttle body
