Results 1 to 10 of 15
Thread: Are speedo clocks a straight swap ?
    Regular Member wu11ie's Avatar
    Jan 2008
    Airdrie
    Trim : Elegance
    Engine : 2.2
    Year : 54
    Default Are speedo clocks a straight swap ?
    My mate has a set of VXR clocks he's getting rid of and i was wondering if they would go into my preface 2.2 signum? Or is it a big job ?
    Thanks,
    Regular Member Ben_'s Avatar
    Audiville, WM
    Removing the clocks isn't there's a good how2 on here somewhere.
    Are speedos the same on both cars?? Otherwise they'll be out of sync won't they?
    Regular Member TrackTiger's Avatar
    Mar 2013
    Notts
    Engine : 2.8
    tech 2 for coding, plus you'll need to alter the mileage via the eeprom chip.
    Edit: above is facelift to facelift, no idea about pre facelift etc.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Eh can you not just swap the actualy clock face/backing (bit with all of the numbers on it) between the two binicles? On another note the preface dashes are different as the facelift ones don't have the window in the rev counter and subsequently have additonal symbols and lights around the clocks because of this - oil level light, coolant level warning, door ajar warning etc.
    Jan 2008
    Airdrie
    Trim : Elegance
    Engine : 2.2
    Year : 54
    I tried a search but i couldnt find anything,
    Whats the difference between tech2 and opcom ?, would i be able to sync them and adjust the mileage using opcom ?
    Jan 2008
    Airdrie
    Trim : Elegance
    Engine : 2.2
    Year : 54
    Quote Originally Posted by GazCDTI150 View Post
    Mine doesnt have a window in the rev counter either, mine is in the speedo the same as his VXR ones, they look the same size and shape etc but its just finding out if anyone knows if theyd work,
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I thought you couldn't change the mileage on them.
    Ely, Cambridgeshire
    62 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The only way you can change the mileage on them as far as I know is to put them back into delivery mode and completely re-set them up from scratch. The guy at Vauxhall who did mine had to then go through and program in all the relevant info in, which other modules were installed that it communicated with (TPMS, Parking sensors etc) and I think he programmed in the chassis number of the car to it too from memory.
    In delivery mode you can then set the mileage to match what's held on the ECU.
    Mar 2013
    Notts
    Engine : 2.8
    Pecky http://www.diagnostics.org.uk/2010/0...ge-correction/ and Stampede are the only people I know who can reset mileage. Best bet is to contact one of them.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    @plasma can aswell
  1. Tps straight swap?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 14th February 2012, 18:57
  2. cdc40 straight swap
    By scotty84 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 23:39
  3. Been offered a straight swap on my vec, what do you think?
    By sri andy in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 11:05
  4. are these a straight swap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2007, 18:43
can I swap speedo on vectra c
swap Vectra c clocks
speedo swap vectra c
vectra c instrument eeprom chip
