Results 1 to 10 of 13
Thread: Central Locking Not working
    Sep 2012
    Stoke on Trent
    Engine : 1.9 CDTi 150 Z19DTH
    Default Central Locking Not working
    Right, need another bit of help,, my central locking isnt working, key fob is knackered so have to lock it with the key for now but it only locks drivers side door the rest will not close, if I close them with the button on drivers door then all 4 doors will close and open, I thought it was drivers side door lock so I changed it but no luck still will not lock or unlock all doors with the key, scanned it with opcom and it comes back with error code B2966-05 "driver doorknob circuit open or high voltage", any suggestions?
    13 Post(s)
    Quote Originally Posted by VA Automotive View Post
    I take it the drivers door is shut when trying, and you're either reaching in from one of the passenger doors to press the lock button onthe panel?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Dammit , looks like Alex has become a fully blown Vec-C Modder ! I guess this means that all the "best bits" will now be getting fitted to his new motor
    Just kidding matey
    Sep 2012
    Stoke on Trent
    Woody you are absolutely right, I have already put eibach suspension in to replace them daft coilovers.
    Memory leather seats from that silver sigi are going in aswell when I get a chance.
    With regards to the lock, yes drivers door is shut and I am pressing the button while on drivers seat.
    Sep 2012
    Stoke on Trent
    Woody dont worry m8, I'll save some for you.
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Cheers Alex, phewwww you had me "worried" for a minute there fella
    Sep 2012
    Stoke on Trent
    Right, any ideas on the central locking anyone?
    South east
    Sounds like you have the same issue as me - on mine the car thinks the driver's door is open even when closed, and therefore when I try to lock the car with the remote, the door pins go down and then come back up. I have a constant warning on the dash that the driver's door is open, but I'm not sure all versions of the Vec come with that facility.
    Sep 2012
    Stoke on Trent
    No mine does not do that , it does lock from inside when you press the button, all 4 door lock. But when you try to lock it
    with the key, not the fob, it will only lock or unlock drivers door, I have changed DS door lock, both door switches but still no luck.
    13 Post(s)
    Having re-read your original post, the driver door lock is working correctly.
    At some point Vauxhall changed the lock/unlock procedure so that all doors will only lock/unlock with the remote or by using the buttons on the driver door panel.
    My old 53 reg (2004) Vectra Elegance locked/unlocked all the doors with the key, but my current 06 (2006) doesn't.
    It's documented in the handbook.
  1. electric window /central locking not working
    By jonnybravo in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2016, 18:42
  2. Central locking fob only working inside the car
    By chunkey_monkee in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 22:51
  3. central locking door button stopped working
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2011, 22:47
  4. Central Door Locking not working after disconnecting battery
    By onlymeagain in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2010, 10:06
  5. Central locking not working
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2010, 11:00
vectra c central locking not working
vectra c central locking not working with key
https:www.vectra-c.comforumshowthread.php186302-Central-Locking-Not-working
vectra c fob central locking not working
opel vectra c 2004 central loking not work
central lock fuse opel vectra
vauxhall signum central locking
opel vectra 2005 central lock doesn`t work
vauxhall vectra key fob not working
central locking fuse Vectra
vauxhall vectra a central locking fault
vauxhall vectra c central locking not working
2.2 petrol signum cetral locking trouble
opel sigmum centrla lock from inside not qorking
central locking vectra c other doors problem
Vectra c locking problem
vauxhall vectra c central locking fault
vauxhall vectra c central locking stopped working even with the key
opel vectra c 2005 1.9 cdti central locking not working
vectra c 55 central locking stop working
vectra central locking not working
central locking on vectra cdti stopped working
central locking not working from a distance insignia
vauxhall vectra central locking not working
vauxhall vectra 2005 central locking not working
