Thread: Speed related Noise on a CDTi 150
    North Herts
    confused Speed related Noise on a CDTi 150
    My 2007 ,100K miles CDTi 150 has developed a speed dependant noise that seems to be from the front
    It starts of quietly at about 40mph, builds up to 60mph then seems to fade after that, at 60mph there does seem to be a buzz through the steering wheel
    The closest I can describe the noise is that it's a bit like the noise you get from a roof rack
    I've checked the wheel bearings on jacks
    It stays noisy coasting in neutral or dipped clutch
    Noise doesn't change with braking
    I've had the front/rear wheels swapped
    The local garage can't find a problem with the driveshafts (they didn't do a road test)
    I've had a prod at the undertrays etc, can't see anything loose.
    Anybody got any ideas before I take it to a gearbox specialist for wallet removal ?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    What make tyres do you have fitted..?
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    The noise you,ve explained does sound like a wheel bearing,if it was the box i thought you would have heard it from the off,wheel bearings can start whining at any given speed and dissapear at any given speed.
    North Herts
    Pirreli P7 all round. The fronts were pretty worn so I changed them, still noisy
    Quote Originally Posted by marko1966 View Post
    There is no play or rumble when spinning or wobbling the wheels on jacks, also no warmth in the hubs after a 250 mile trip. I'm hoping it's a grumbling bearing, a lot cheaper than a new gearbox
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    I wonder would it be the carrier bearing on the long driveshaft? Friend of mine had a whinning noise at around 60mph like a wheel bearing but they all seemed fine so on closer inspection he noticed the bearing looked very rusted up, so he chanced changing it and the noise is gone!!
    North Herts
    Quote Originally Posted by Monkgti View Post
    I'll have a look under the car at the weekend
    North Herts
    It took another 3000 miles of use to get it noisy enough for the garage to hear it, I must have finely tuned ears. It was the nearside wheel bearing grumbling !
    East Ayrshire
    Trim : SRI XP1
    At least you finally got it fixed. Did you have any handling issues whilst it was like that?
  1. 1.9 8V CDTi lumpy take off EGR related possibly
    By AndyChadwick in forum Engine & Drivetrain
    Last Post: 22nd March 2013, 01:02
  2. Noise from wheels at speed...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2012, 12:41
  3. Noise over speed bumps
    By scooby8272 in forum Suspension, Wheels & Brakes
    Last Post: 1st October 2010, 13:32
  4. CD70 - How do you adjust speed related volume!
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 17:46
  5. another funny noise - brake related
    By carl bear in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2007, 17:46
carrier bearing vectra
has vectra got a carrier bearing www.vectra-c.com
