Thread: Noisy parcel shelf
    New Member NedVincent's Avatar
    Mar 2013
    Mid Norfolk
    Trim : SRI
    Engine : 1.8 VVT
    Mileage : 76 000
    Default Noisy parcel shelf
    Last few days my parcel shelf has been doing my head in bouncing up and down and rattling. Today i put a jumper on top of it to deaden the movement and its dead quite.
    What would people suggest i do for a long term fix? What have others done if they have the same issue? Keep something on it or try and pad the areas that band together?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
    to cure my parcel shelf rattle i put some cloth round the ends where you slot it in to the car
    no rattle now
    Nov 2009
    newcastle
    Your rattle as other threads will be hinges (wrap some tape around to tighten gap up)
    but more likely it is at back end. Look on boot lid inside there are 2 rubber mounts that squash against the shelf and stop the rattle. I found i could see one side rattling in mirror and other side ok so have a look so you arnt wasting time if side isn't broken. adjusting the rubber mounts in lid a bit and might work. If not you need to raise the shelf prob half an inch to push back against the lid. ( there's a good how2 linked above on doing it properly.try a temporary fix to check it works by using a small item (say a bottle top) and use a black tape to fasten in place while you see if its that.
  1. Noisy parcel shelf
    By 1232nayl in forum Bodywork & Interior
    Last Post: 21st September 2011, 20:45
  2. Parcel shelf
    By danno91 in forum Bodywork & Interior
    Last Post: 13th September 2011, 19:58
  3. parcel shelf pin
    By scarydeath in forum Bodywork & Interior
    Last Post: 11th September 2011, 21:00
  4. noisy parcel shelf
    By effone in forum Bodywork & Interior
    Last Post: 11th February 2009, 22:00
  5. help with parcel shelf
    By kevin hunter in forum Bodywork & Interior
    Last Post: 12th January 2009, 20:45
noisy parcel shelf vectra
