Thread: Vectra cutting out at running temperature
    Aug 2011
    Northern Ireland
    Default Vectra cutting out at running temperature
    2003 vectra sri 3.2 v6
    Well everything else seems to be dead on apart from when the car gets up to normal running temperature and it cuts out now and again of its sitting on idle but if its driving and you put the foot down sometimes its gives a wee jerk as if its trying to cut out and the battery, traction control and engine managment lights come on and go off again but the traction control stays on..
    Have had the car plugged in and its not showing any faults,
    Anyone got any idea what this could be?
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    not sure but someone here might have an idea. Strange that there's no codes flagging up.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Would need live readings before condemning anything mate
    coolant sensor.coukd be a failing cam/ crank sensor.
    whats your temp like?
    Aug 2012
    South Wales
    Is it an automatic one because I bout one a year ago and had exactly the same trouble 06 plate the car sales place had it more than I did and the found it to be a problem on some rail and selector in the box they had it back in the end as it would cost to much for them to repair over 2 k they said don't know if that helps at all mate
    Aug 2011
    Northern Ireland
    Temp and all is fine its heating up and fan kicking in when it needs to.. Just sometimes on idle it will just conk out, then when you give it some revs of take it a drive it plays up when you put the foot down,
    Aug 2011
    Northern Ireland
    Sorry no its a manual
  1. CDTi 150 Running Temperature
    By tony-1977 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:38
  2. coolant running temperature?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 13:24
  3. Running Temperature 1.8 vvti SRi???
    By bigrory1986 in forum Engine & Drivetrain
    Last Post: 14th September 2009, 14:07
  4. Engine coolant not getting to running temperature
    By richard1707 in forum Engine & Drivetrain
    Last Post: 11th August 2009, 23:19
  5. 2.0 DTI Water Temperature? Running cool?
    By StephNET in forum Engine & Drivetrain
    Last Post: 6th September 2008, 11:08
vauxhall signum cuts out at running temp
