Thread: Loose Drivers Outside Door Handle
    Apr 2012
    Glasgow
    Default Loose Drivers Outside Door Handle
    Hi, 2007 SRi model. Door handle is loose on the drivers door, Works as normal etc but is very wobbly. Is there any way adjusting the torx screw behind the gromit will help and if so by what way?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Turn it clockwise couple of turns an see if it helps
    Apr 2012
    Glasgow
    Thanks, il give it a go.
    Apr 2012
    Glasgow
    Did Screw was solid, handle was easy to remove but its the internal spring or retun part thats the issue its not as strong as it was to keep the handle snug against the door fitting. I did try swapping handles but no use, looks like a door card of job,
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Looks like you need new back plate mate
    pick them up for about tenner In a scrappy
    Oct 2014
    scotland
    Vehicle : vectra 1.9cdti 150 sat nav
    Trim : sri
    Engine : 1.9
    Year : 08
    Mileage : 122000
    handle was easy to remove but its the retun part thats the issue its not as strong as it was to keep the handle snug against the door fitting.
    Quote Originally Posted by Critch View Post
    Critch do you have pics of this item you are talking about? is there a link to one on the forum somewhere? im having the same issue, handle operates but feels looser than the rest and will pull out further before it opens the door/ then it wont spring back tight to rest position it sits out a bit....is this the same thing i need? or is it internal in the mechanism? will this fix be a door card off ? please advise, thanks
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    I don't have a picture unfortunatly no
    ask one of the breakers on here I'm sure they'll have the part
  1. Drivers Seat Back, moving appears loose
    By robster23 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 16:55
  2. Cable has come off on drivers door latch not handle
    By chriso123 in forum Bodywork & Interior
    Last Post: 11th November 2012, 16:01
  3. Door handle loose
    By barachello in forum Bodywork & Interior
    Last Post: 20th May 2011, 09:03
