Thread: Vec C 1.8 SXI thermostat
    Jan 2013
    Huddersfield
    Default Vec C 1.8 SXI thermostat
    Just a quick question, been hunting to find the answer so I can get the right part on its way to me, will my Vectra C 1.8 petrol sxi swap without replacing the housing aswell?
    Thanks in advance!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    newport
    i done it both ways, old car i replaced just the stat, only lasted a couple of months though, dont know whether it was the cheap ebay one i bought or something else, but on our current car, i bought the whole housing/stat with the new sensor already attached from vx, and replaced the lot for £42 all in, and 6 months on still going strong.
    got to admit, i got lazy with the draining the coolant, the coolant drained when i unbolted the housing from the engine lol
    Jan 2013
    Huddersfield
    I think it is the X18XE engine, but I haven't checked the chassis stamp, is there one under the bonnet and if so, where? The one I've bought seems a reasonable kit, stat and 3 O-rings, around 12squid. If it becoming problematic, as I want to turn this motor into a good reliable runner I'll change the lot for QH housing and stat.
    I am also going to change the water temperature sensor too while I'm at it.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Pre 2005 then It will be the Z18XE. Its basically the same engine as the Vec B X18XE, but the main difference is that the Vec C has a Fly By Wire throttle, instead of cable operated throttle on the X18XE.
    Jan 2013
    Huddersfield
    Das-thank you, answered it all.
  1. Is my thermostat gone
    By Mark-R in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2012, 10:24
  2. Possible Thermostat?
    By Stu C in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 20:39
  3. 2.2 dti thermostat
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 22:29
  4. thermostat 2.2 dti
    By tomo610 in forum Diesel Engine related
    Last Post: 9th January 2011, 22:25
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
